Literati914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,999 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
How much would you expect to pay for an original 914-6 engine that is in need of a rebuild? I have the engine serial number code... where can one verify that it's an actual original 6 from a 914?
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Unless the car is a real /6 and to many a numbers matching engine it's just a 110hp '69 911T engine.
Rebuild cost is basically the same for a 2.0 thru 3.2 Aluminum case is the reason many conversion owners go for the 3.0 and up engines. |
Mike Fitton |
Senior Member ![]() ![]() ![]() Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest ![]() ![]() |
This should help you:
http://forums.pelicanparts.com/porsche-911...ine-number.html |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,376 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Please post the engine serial number. You never know, it may have been an engine out of a car someone here owns and is looking for their original motor. (IMG:style_emoticons/default/beerchug.gif)
gereed75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,367 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States ![]() ![]() |
That link tells you how to ID a six motor.
Price - depends on condition and completeness. Completeness includes things like carbs, exhaust, sheet metal, shroud, alternator, carb linkages etc. A decent core long block might be had for as low as $1500 with a decent complete core motor going for maybe as much as $5000.00 Things like Weber carbs go for $2500 - $3500 alone. |
Literati914 |
The engine number's 6405672/901/38
gms |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,721 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest ![]() ![]() |
VIN for this engine should be around 914.043.2500 (+/- 50)
altitude411 |
I drove my 6 into a tree ![]() ![]() ![]() Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains ![]() ![]() |
Unfortunately the game of matching engine numbers to the car of said engine is no longer playable, unless you already have your COA. https://rennlist.com/forums/911-forum/10290...ion-number.html
This engine number is possibly in the realm of my sixes vin # but I'll never know (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/headbang.gif) Today's COA's; just a nice looking document? |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,876 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Yes not worth a lot but generally these motors don't suffer like the later mag case 2.7 for example ,will run for a fair while before they just wear out ,sad thing is the body has turned to dust and been scrapped long before.
Would be interesting to know how many real six's are around now...can't be many left from a small production run,makes sense good conversions are moving up in value. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,956 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
$2,500 - 3k without carbs.
Case is $1,200 Crank is $1,000 Can and shroud $500 Heads $300 |
larryM |
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California ![]() ![]() |
901/38 was a 70-72 USA-emissions 914/6 engine (per Bruce Anderson's performance book)
- not an alu case (those are worth MUCH cuz you can secretly build 'em into durable stealth big motors and get past the scrutineers at vintage race venues that monitor such stuff) p.s. - 110 hp DIN = 125 SAE as advertised back then FS- $13,500 ask - rebuilt 6404534 http://www.914world.com/bbs2/index.php?showtopic=329465 i sold a decent rebuildable 901/38 long block for $500 a few yrs ago - not worth rebuilding one imho - - dunno why anyone would really want a oem 2.0 with non-counterweighted crank & gasketed cyl heads, unless one is obsessed with number matching for auction value, and does not care much about performance |
gandalf_025 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,498 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States ![]() |
I bought a core 914-6 long block from a member here
a few years ago for 3500.00. It turns over freely and has 2.0 āSā pistons and cylinders and Solex Cams.. Needs a rebuild though. It might just end up in my 6 as a driver. My original engine is sitting on a shelf with 30,000 miles on it. A small engine will go into my car without issue and not run too hot. How fast can You really Drive a car where you live.?? I like My insurance rates the way they are. No tickets In years and that matters when you are insuring 5 cars and a motorcycle.. |
Lo-Fi Version | Time is now: 6th July 2025 - 11:57 AM |
