Found: spare wheel Thank you for contributing., With 5 lug bolt pattern |
HansJan |
May 22 2018, 09:48 AM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
I’m looking for a spare wheel. Needs to fit the 5 lug (at 130 mm BDC) pattern. Thanks for looking. |
theer |
May 22 2018, 10:14 AM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Hans,
need more information - 15", 16"? Any particular design: Fuchs, BBS, doesn't matter? By the way, modern Porches mostly all have the 5 x 130 bolt pattern, so a cheap spare might be a phone dial or cookie cutter wheel from the 944 crowd. Just be sure the offset works with your set up. |
914Sixer |
May 22 2018, 11:17 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Boxster wheels will work too
jim_hoyland |
May 22 2018, 11:22 AM
Get that VIN ? Group: Members Posts: 9,318 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Like this steel 5 lug ?
Attached thumbnail(s) |
HansJan |
May 22 2018, 12:10 PM
The car has 16 Fuchs on it.
It has standard breaks and the disks are redrilled (from 4 to 5 studs). Looking for spare that fits into the standard spare tire space, in the front. Don’t care about the design or looks. It’s not being used for windshield washer. Hope that is enough info. |
burton73 |
May 22 2018, 12:23 PM
burton73 Group: Members Posts: 3,547 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
If you put a tire that is fat the carpeted hard board that sits above it will not sit right.
Try to get something that does not weight that much. Bob B |
burton73 |
May 22 2018, 12:24 PM
Jims spare should work well for you.
914Sixer |
May 22 2018, 12:34 PM
You can pick up 6x16 Boxtster wheels for $100. 911 16" spare wheels are $300 and up.
Gulf91474 |
May 22 2018, 01:17 PM
Member Group: Members Posts: 54 Joined: 3-April 15 From: salt lake city utah Member No.: 18,591 Region Association: Intermountain Region |
Got this sitting around.... 60$ Plus shipping.....
HansJan |
May 23 2018, 09:40 AM
carl k |
May 23 2018, 08:16 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
Lo-Fi Version | Time is now: 7th June 2024 - 08:58 PM |
