Biggles |
Member ![]() ![]() Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England ![]() |
Hi All,
Please can someone advise how i go about installing this Balupunkt Hamburg radio in my -6 car? It didnt have a radio when i bought it so I don't have a reference. I've been given a couple of brackets with the 'new' radio but i can't see how it's supported on the bulkhead or from above. I've included a few pics of what i've got, plus one from ebay which shows the U shaped bracket being screwed onto the back - is this right, and what else does it attach onto? thanks Chris. Attached image(s) ![]() ![]() ![]() ![]() |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,900 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
there is a factory blaupunkt u clip that hangs into the two round holes in the firewall bracket, and two clips that bolt around the knob shafts. Then the radio "snaps" in and you install the factory brickweave faceplate with double faced tape and then the radio trim plate then the knobs.
jdamiano |
Member ![]() ![]() Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States ![]() |
here is a picture of the clip. Not sure where you would buy one. I made mine. I also made two tabs that go on the knob shafts to sandwich the dash between my tabs and the faceplate.
Attached image(s) ![]() |
Biggles |
there is a factory blaupunkt u clip that hangs into the two round holes in the firewall bracket, and two clips that bolt around the knob shafts. Then the radio "snaps" in and you install the factory brickweave faceplate with double faced tape and then the radio trim plate then the knobs. thanks George. Seems like from jdamiano's post i have the wrong clip at the back. just seen this link which illustrates things if others are wondering: http://www.914world.com/bbs2/index.php?showtopic=319799 |
Biggles |
gcrotvik |
Member ![]() ![]() Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest ![]() |
here is a picture of the clip. Not sure where you would buy one. I made mine. I also made two tabs that go on the knob shafts to sandwich the dash between my tabs and the faceplate. Be aware there is a long and a short "C" clip. If you have a short depth Blapunkt chassis, the short clip may not be long enough. If you a long depth chassis. the short and the long "C" clip will work. The clip in the picture is the short clip I believe. Greg |
edrotol |
edrotol ![]() ![]() Group: Members Posts: 190 Joined: 23-April 06 From: Woburn, MA Member No.: 5,910 Region Association: North East States ![]() |
here is a picture of the clip. Not sure where you would buy one. I made mine. I also made two tabs that go on the knob shafts to sandwich the dash between my tabs and the faceplate. thanks. Does anyone have one ? Have one.$60.00 plus shipping to UK. Can send picture if interested to your email address. Let me know. |
Biggles |
here is a picture of the clip. Not sure where you would buy one. I made mine. I also made two tabs that go on the knob shafts to sandwich the dash between my tabs and the faceplate. thanks. Does anyone have one ? Have one.$60.00 plus shipping to UK. Can send picture if interested to your email address. Let me know. Thanks but for $60 I’ll make one ! |
Biggles |
here is a picture of the clip. Not sure where you would buy one. I made mine. I also made two tabs that go on the knob shafts to sandwich the dash between my tabs and the faceplate. Be aware there is a long and a short "C" clip. If you have a short depth Blapunkt chassis, the short clip may not be long enough. If you a long depth chassis. the short and the long "C" clip will work. The clip in the picture is the short clip I believe. Greg Ok thanks Greg for the advice |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,513 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
No one has mentioned this so I will. If drilling, just remember the gas tank sits about 1/2" on the other side of that bulkhead.
jdamiano |
No one has mentioned this so I will. If drilling, just remember the gas tank sits about 1/2" on the other side of that bulkhead. When I made my clip I used a big punch at an angle against wood and made the tabs that fit in the holes in the firewall bracket just like the one made for the job. I used some needle nose pliers to shape the tabs. |
Biggles |
No one has mentioned this so I will. If drilling, just remember the gas tank sits about 1/2" on the other side of that bulkhead. When I made my clip I used a big punch at an angle against wood and made the tabs that fit in the holes in the firewall bracket just like the one made for the job. I used some needle nose pliers to shape the tabs. Thanks, yes I’d agree with that approach for thin gauge metal. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
No one has mentioned this so I will. If drilling, just remember the gas tank sits about 1/2" on the other side of that bulkhead. When I made my clip I used a big punch at an angle against wood and made the tabs that fit in the holes in the firewall bracket just like the one made for the job. I used some needle nose pliers to shape the tabs. Thanks, yes I’d agree with that approach for thin gauge metal. Yeah that will work but just go for a metal fastening bracket as in the pic.....good way to stop some bugger stealing your nice restored radio. I ditched the Blaupunkt clip for my newer Blaupunkt h/unit cause it wouldn't fit made a bracket to hold the unit solid. My original euro Frankfurt stays in my collection in a safe place (IMG:style_emoticons/default/beer.gif) . |
Lo-Fi Version | Time is now: 15th June 2024 - 01:55 PM |
