Transmission surgury, which guts are better???? |
jr91472 |
Jun 10 2005, 01:39 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Background: I am working to take the best parts from 2 trannies and make one.
One tranny has yellow (brass?) shift forks and the other one has black. Any difference or preference? Also, the one with the yellow forks also has yellow bearings. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) this weekend (hopefully) I will start dismantling both gear stacks and inspecting sliders, dogteeth, and syncro's.....this is a blast!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) thanks all (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
Cap'n Krusty |
Jun 10 2005, 01:44 PM
While you're dismantling those trannies, remember that the paper gaskets between the tunnel case and the intermediate plate are SHIMS, and you need to preserve that precise thickness, WITHOUT any sealant. There are also shims on the pinion shaft that set the depth. Don't lose them and don't swap them! The Cap'n
jr91472 |
Jun 10 2005, 01:51 PM
Thanks Cap'n!! I was lucky that the shims on the box with the "good" ring gear came out completely intact. They are safely tucked away for measurement before re-assembly. Question, though....what did you mean by "don't swap them". Do you mean don't replace them with new ones (of same thickness of course)? |
JWest |
Jun 10 2005, 01:52 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
They are brass - clean the "black" ones more to make them "yellow" too. Maybe they got overheated, or maybe that trans had very "clingy" gear oil.
jr91472 |
Jun 10 2005, 01:58 PM
ahha!!! (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) we really need a yoda smiley! interesting James, the black ones came out of my own tranny which "supposedly" only saw synthetic gear oil while in the PO's possession. |
JWest |
Jun 10 2005, 02:05 PM
Scratch one and see if they are brass.
jr91472 |
Jun 10 2005, 02:10 PM
yep...you nailed it |
bondo |
Jun 10 2005, 02:15 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I'm sure they're brass... I took apart 7 trannies, and the brass parts had many different colors, ranging from shiny and new looking to black.
To preserve pinion adjustments, keep the case, intermediate plate, side cover, ring, pinion, bearings, shims and 2nd-5th gears together. Swap syncros and sliders all you like, but keep all that other stuff from the original trans. |
jr91472 |
Jun 10 2005, 02:21 PM
Thanks Royce! I had not considered that the actual gears might impact pinion depth. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) fortunately, it looks like the dog teeth on the gears are all in pretty good shape. But I will definetly be robbing the 4/5 slider and using it as a 2/3 slider. thanks again everyone. |
jr91472 |
Jun 29 2005, 06:00 PM
Well its done and I took her for a quick ride. Every gear shifted great and that roar that was my bad ring/pinion gear is gone! (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
I did detect a little gear whine (especially in 2nd), not sure what that is. I did have to use the pinion bearing (intermediate plate) from my old tranny, so could be that. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) But if all continues to go well, I will definitly live with it (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) Thank you James Adams for the cheap ass parts! Thankyou Clay for tools and advice! And thankyou Bondo and Redbeard for some kick ass articles and photo's!!! this site rocks (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:21 PM |
