WTB- One Wire from 75 Harness, Need the Black with a Red Stripe Fuel pump wire. |
ClayPerrine |
Jun 6 2018, 05:17 PM
Life's been good to me so far..... Group: Admin Posts: 15,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
All...
I am looking to buy the fuel pump wire from a 75 (or 76) 914. It is black with a red stripe and runs from the relay board in the engine compartment to the left side of the car under the gas tank. I want my DME in my 4.0 to have the correct wiring color codes. This is the one I don't have. If you have a junk harness from a 75, I would like to purchase the fuel pump wire. Thanks! |
tweet |
Jun 6 2018, 05:21 PM
Member Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
If you don't find it here, Jeff Bowlsby may be able to make it for you. He specializes in wiring. He also has his own site:
http://bowlsby.net/914/WiringHarnesses/ |
914Sixer |
Jun 6 2018, 06:11 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Clay,
Left me see what I have in the warehouse. I have a couple of harnesses. |
Luke M |
Jun 7 2018, 07:28 AM
Senior Member Group: Members Posts: 1,380 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
JeffBowlsby |
Jun 7 2018, 08:12 AM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
You need 12 gage black/red stripe and 12 gage brown for the ground. I don’t stock it.
JFJ914 |
Jun 7 2018, 09:06 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
I got that color code (Black/red stripe) at NAPA. Was 14 ga , works fine.
JeffBowlsby |
Jun 7 2018, 09:13 AM
14 ga may work, but is undersized...per the factory schematic.
914Sixer |
Jun 7 2018, 01:27 PM
My harness was cut in two pieces. It is solid red though.
JeffBowlsby |
Jun 7 2018, 06:17 PM
Solid red is direct battery power from the battery to the relay board and or ignition switch depending on year. The fuel pump circuit is black/red on all 914s.
cary |
Jun 8 2018, 09:00 AM
ClayPerrine |
Jun 8 2018, 05:31 PM
You need 12 gage black/red stripe and 12 gage brown for the ground. I don’t stock it. I already have the ground taken care of. The fuel pump for the MFI is already up front. I just need to go from the DME relay in the engine compartment to just above the relay board where the current fuel pump wire terminates. I would like to have a factory wire. Clay |
Lo-Fi Version | Time is now: 11th June 2024 - 08:51 PM |
