majkos1 |
Member ![]() ![]() Group: Members Posts: 218 Joined: 11-August 17 From: Mile High 914 Member No.: 21,338 Region Association: Rocky Mountains ![]() |
eric9144 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California ![]() ![]() |
The ones hanging on your bench are some home brew stuff... The ones on the car however, are the Euro version of the US driving light and use an H3 bulb, they're cool and rare-ish, probably a lot better for actual lighting than the US fog light version.
majkos1 |
The ones hanging on your bench are some home brew stuff... The ones on the car however, are the Euro version of the US driving light and use an H3 bulb, they're cool and rare-ish, probably a lot better for actual lighting than the US fog light version. Thank you Sir! I was at a Concourse last summer and a couple of guys were pointing at my fog lights and were bickering. I'm deaf and read body language.. One was sure! and the other wasn't I was with a few folks talking ,(sorta) Couldn't really hear em and observed the two gentlemen, I try to get away and ask these Gents, but.... I have notice they require certain bulbs, obtain a couple to replace the one burn out one but have to remove the bumper to put in bulbs? I knew then something was amiss. Thanks again for insight. |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,622 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
The ones hanging on your bench are some home brew stuff... The ones on the car however, are the Euro version of the US driving light and use an H3 bulb, they're cool and rare-ish, probably a lot better for actual lighting than the US fog light version. Thank you Sir! I was at a Concourse last summer and a couple of guys were pointing at my fog lights and were bickering. I'm deaf and read body language.. One was sure! and the other wasn't I was with a few folks talking ,(sorta) Couldn't really hear em and observed the two gentlemen, I try to get away and ask these Gents, but.... I have notice they require certain bulbs, obtain a couple to replace the one burn out one but have to remove the bumper to put in bulbs? I knew then something was amiss. Thanks again for insight. Yes on removing the bumper. Easy to do though... |
majkos1 |
How were these , ? available?
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,909 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Bottom lights are European driving lights. Never issued here but a few got imported. Interesting front bumper with 75-76 bumper pads.
ConeDodger |
majkos1 |
majkos1 |
I like small tits over big tits,
wait! should this be in Sand box? |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I like small tits over big tits, wait! should this be in Sand box? ILBT (IMG:style_emoticons/default/laugh.gif) |
eric9144 |
I have a set, bought in the early 90s and kept in the boxes, part numbers 914 631 131 10. My lenses had fogged a little on the insides but the cleaned up easily. Not for sale (IMG:style_emoticons/default/beerchug.gif)
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Got the lenses and the seal for them -
https://shop.914rubber.com/Porsche-911-fog-...m?categoryId=-1 Also in amber Slightly larger than the 914 version Attached thumbnail(s) ![]() |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,503 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
You say slightly larger than the US version. Does that mean they do not fit the housings for the 914 US version?
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Yes on removing the bumper. Easy to do though... Possibly yes in this case. With the stock front valence, there is a dimple in the top of the valence that lets you get a screwdriver through to the screw that holds the lens onto the body of the light. The lens can then be removed (with some difficulty) and the bulb replaced. Alternately, the grille can be removed from the bumper with four screws, and the rest can be worked around. But if you have a second pair of hands available, it is certainly easier to just remove the bumper to get access. These lights definitely are larger diameter than the ones I am familiar with. --DD |
eric9144 |
majkos1 |
majkos1 |
majkos1 |
horizontally-opposed |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None ![]() ![]() |
Got the lenses and the seal for them - https://shop.914rubber.com/Porsche-911-fog-...m?categoryId=-1 Also in amber Slightly larger than the 914 version Just ordered a set from you in case I rebuild mine...thanks for the heads up! These are very cool lights. Offer more light and fill out of the holes in the bumper grilles just a bit nicer. Definitely a detail, but a neat one. What surprises me is how rarely I see them in the U.S. They sold a fair few Euro 914s that rusted into oblivion...would have thought these would have been harvested from those cars? And were they used on anything else, like a Benz maybe? |
majkos1 |
took apart the Home brew Fog lights (IMG:style_emoticons/default/smash.gif)
![]() ![]() ![]() ![]() Replacements are From GE. |
Lo-Fi Version | Time is now: 16th June 2024 - 12:23 AM |
