Am I ... missing something?, Swaybar parts... |
Brando |
Jun 11 2005, 09:35 AM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
I think I have everything I need to get my front swaybar mounted up
Just yesterday I got the Weltmeister 22mm Adjustable swaybar from McMark (thanks dude! (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)). It was the swaybar itself and the solid pieces that come down to the A-Arms with droplinks. I then bought the U-tabs from Engman and the triangle weld-in reinforcement plates. Is there anything else I need? I've seen these funky dought-triangle brackets on some cars... do I need those for the swaybar I have? TIA |
neo914-6 |
Jun 11 2005, 09:48 AM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
I have the same bar, Do you have the plastic bushings and triangular cup bracket that holds them to the fender well? They bolt to the Engman bracket. If you need the 6 bolts, I have the correct mm and hardness that Engman spec'd...
Brando |
Jun 11 2005, 10:18 AM
I guess I need that traingle bracket thingamabob and the bolts.
Where can I get them all? |
neo914-6 |
Jun 11 2005, 10:29 AM
I bought a box bolts from McMaster Carr so I have been giving them away, or you can buy them from a metric hardware store. I was later told you can buy the bolts individually from MC but they were cheap. You can get the brackets and bushings from GPR and probably other places...Actually I got lucky and go my brackets off eBay. 19mm and 22mm are the same but the bushings have the different ID.
Lo-Fi Version | Time is now: 10th June 2024 - 06:20 AM |
