How important is the fuel tank sock? |
andreic |
Jun 10 2018, 04:29 PM
Member Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
The other week I had some problems with low fuel pressure on my 1972 914 1.7L. I have now diagnosed these by pulling the tank out -- one of the hoses under it was kinked.
However, while inspecting the fuel tank I discovered that there is no "sock" inside the tank. How worried should I be? Should I use this opportunity that the tank is out to add a sock? Or is it not a big deal to run the car only with a fuel filter, without the sock? Thanks, Andrei. |
bandjoey |
Jun 10 2018, 05:01 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Important
TheCabinetmaker |
Jun 10 2018, 05:55 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I thought Jeff did a good job of answering that question in your other thread!
andreic |
Jun 10 2018, 06:04 PM
Got it. I already fully emptied the tank, I'll get a new sock and install it. As far as I could understand, this involves taking out the larger fitting from the tank and installing the sock over the end of it the tube that goes into the tank. Do I need any kind of washers/gaskets to seal the fitting back to the tank when I put it back in?
Thanks, Andrei. |
jim_hoyland |
Jun 10 2018, 06:42 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Years ago, a Porsche mechanic suggested deleting the sock and let the easily replaceable filter catch any debris. Kinda made sense since the filter gets replaced periodically anyway; the sock is another story.
Thought this made sense Considering the fuel socks proximity |
worn |
Jun 10 2018, 08:43 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
The other week I had some problems with low fuel pressure on my 1972 914 1.7L. I have now diagnosed these by pulling the tank out -- one of the hoses under it was kinked. However, while inspecting the fuel tank I discovered that there is no "sock" inside the tank. How worried should I be? Should I use this opportunity that the tank is out to add a sock? Or is it not a big deal to run the car only with a fuel filter, without the sock? Thanks, Andrei. I don’t see how you can replace the sock with fuel in the tank, so now is the time. They are cheap and easy to find. On the other hand fuel injectors are expensive and carb rebuilds take time and care. Have to say this is a clear choice. At least for me. |
914 RZ-1 |
Jun 10 2018, 09:58 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
Does someone have a picture of this sock? My '72 does not have one.
Any links to Pelican Parts or other vendors that carry this would be appreciated as well. |
Lucky9146 |
Jun 10 2018, 10:07 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,617 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
I bought the screen from AA because I thought he had the best deal on the nut and I needed that. Best of luck!
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) |
Steve |
Jun 10 2018, 10:28 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Curious is that a gasket or some sort of washer with the kit from AA
Lucky9146 |
Jun 10 2018, 10:45 PM
I bought the screen from AA because I thought he had the best deal on the nut and I needed that. Best of luck! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) Not A Kit! The nipple and red gaskets were from Bruce Stone The strainer and nut from AA Don't recall where the copper gasket came from (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/white914.jpg) |
Drums66 |
Jun 10 2018, 11:02 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Years ago, a Porsche mechanic suggested deleting the sock and let the easily replaceable filter catch any debris. Kinda made sense since the filter gets replaced periodically anyway; the sock is another story. Thought this made sense Considering the fuel socks proximity .......I also deleted the sock, no problems...going on YEARS! (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/bye1.gif) |
andreic |
Jun 11 2018, 10:27 AM
Where do all the washers/gaskets go?
maf914 |
Jun 11 2018, 03:47 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Where do all the washers/gaskets go? I was wondering the same thing. In the order shown in Lucky9146's photo? All outside the tank? Here is the PET diagram. See parts 8 to 14. Still not clear. (IMG:style_emoticons/default/idea.gif) Attached thumbnail(s) |
xperu |
Jun 11 2018, 03:55 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:02 AM |
