JFG |
Senior Member ![]() ![]() ![]() Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None ![]() |
I'm running twin 40's, previously listed and agreed ok. When my engine is hot (thermostat open) the engine struggles and dies.
I thought could be crap in tank / filter but have checked and replaced with no change. As this happens only when hot could this be fuel evaporation due to manifolds being to hot on the head? |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,245 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
As this happens only when hot could this be fuel evaporation due to manifolds being to hot on the head? Yes, it could be. Are you running the phenolic (sp?) spacers/insulators between the intake manifolds and the heads? They are important in keeping the manifolds (and carbs) cooler. Also a good idea to utilize the return line to the tank to keep the gasoline moving. A lot of people plug it when they convert to carbs but moving fuel is less likely to boil in the float bowls. (IMG:style_emoticons/default/popcorn[1].gif) |
JFG |
I have the manifold fitted to head with only a gasket.
A quick search shows up spacers from 3 to 9mm. What should I be looking at? Too far and that may cause linkage issues on the csp bellcrank linkage. No return so I may get a knock on from the bowls but I'll rule out one thing at a time. These are an example https://www.dellorto.co.uk/shop/weber-carbu...nsulator-plate/ |
SirAndy |
I have the manifold fitted to head with only a gasket. A quick search shows up spacers from 3 to 9mm. What should I be looking at? Too far and that may cause linkage issues on the csp bellcrank linkage. No return so I may get a knock on from the bowls but I'll rule out one thing at a time. These are an example https://www.dellorto.co.uk/shop/weber-carbu...nsulator-plate/ The phenolic spacers are the ones that came stock on our engines with the fuel injection and insulate the runners from the heads. Last i checked (it's been a few years) they were still readily available from all the usual sources. I used them on my carbed 2056 and it made a big difference ... (IMG:style_emoticons/default/smile.gif) |
SirAndy |
They look like this and go between the head and the bottom of the intake runners, they are several mm thick:
PS: I used a thin film of sealant on both sides, not sure if that is needed but it seemed like a good idea at the time (IMG:http://www.914world.com/bbs2/uploads_offsite/i.ebayimg.com-179-1528748955.1.jpg) |
JFG |
after having properly driven the car the other day on a 6 mile loop i just about limped back onto the drive.
i have the spacers fitted at the bottom of the manifolds but i think it's not enough and i still have the same problem. the car runs like a dream when cold and warming up but the driven heat seems too much. i'm going to fit a return pipe back to the tank and hopefully that will cure the issue. now i need to look at how to fit (in a tidy way) the return pipes in the engine bay. |
falcor75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia ![]() ![]() |
Also how old is your coil? it was discussed in another thread with the same symptoms...
JFG |
the coil was new with the distributor about a year ago. i touched it to see if it overheated but wasn't very hot.
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
It seems to me that your jetting might be a bit off. All my Type-4s with carbs coughed , sputtered and spit when warming up then ran like champ one at temperature.
I am no carb expert to let you know. But your symptoms seem odd to me. That is why the -6 has a hand throttle to let them warm up. Ignition is a possibility check you plug heat range as I got the parts counter guy slipped me the wrong ones once and it cost me a head. |
Lo-Fi Version | Time is now: 7th July 2025 - 04:48 AM |
