SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,245 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
ok, just got back from the AX in alameda. great event, great (fast and loooong) course.
andrew blyholder smoked the whole competition (again), i don't think anyone came even close. my last minute suspension tweak worked out better than expected, car turned in nice. but, of course, now i'm having a new problem ... (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) every time i unload the driver side (left hand turns), that rear wheel just spins. like tire smoking spinning. (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) even in 3rd gear. even in not so tight corners. slight unload and up go the RPM but i'm not moving any faster. obviously, i'm loosing quite some time there. remeber that i'm running the 9" good year schlicks. my 2.0L should *not* be able to spin those at will in 3rd gear. now what? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Andy PS: grant was hauling a$$ out there with his stock 1.8L ! he was only 0.5 sec slower than me! (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) and only until the very last run of the day did i finally beat him ... way to go grant! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
hahaha.. you are the rocketman.. I'd say some type of LSD is in your future, and probably in your past.. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) you are at one, with the Universe. M |
GWN7 |
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region ![]() |
reduce your horsepower (sell engine) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Put a stock 1.7 back in. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
more rear spring / less damper rebound.
the car is rolling onto its left side at turn-in and then the wheel can't get back to the pavement in time for corner exit. undersprung/overdamped - change whichever ONE of those brings you closer to balance. if you like the static over/understeer balance, just take out some damper (the cheaper and easier fix too...) also - and this is the hard part - you must learn to be VERY smooth and precise. if you can turn in exactly the right amount and hold it, it'll help A LOT. when you countersteer it promotes the kind of unloading you're experiencing. easier said than done, i know all to well... |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
Andy, are you still having trouble with your front end lifting like the last photos you shared?
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Andy, just curious of what kind rear spring you are running? Rear shock setting. I would hope you ditched the rear bar. What about front sway bar setting and front torsion bar and shock settings.
Just so I can learn what different combos do to handling. |
grantsfo |
Arrrrhhhh! ![]() ![]() ![]() ![]() Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None ![]() |
Thanks Andy! It was fun having the "who's going to buy everyone beer competition". ..And only my 1.8 engine is still stock, my suspension is pretty well dialed in and as much as I hate it all that fiberglass helped me today. With less weight the car was getting through the slaloms very quickly so I could use all my 85 hp to the max. Thanks for not making fun of my rattle can black deck lids!
From what I saw your car looks a lot better going around corners. ..not lifting that front wheel as much. |
Borderline |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California ![]() |
Andy..You didn't mention right hand turns. Was the right rear spinning in the right handers??? Could be a corner wt. problem. just my .02
Bill |
Demick |
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 ![]() ![]() |
As Joe mentioned, do you have a rear bar? If so, that will lift the inside rear wheel and let it spin like that.
Demick |
SirAndy |
no rear bar, 180lbs progressive springs in the rear, bilstein shocks ...
front is all '84 carrera with stock 911 boge shocks and a 22mm hollow sway bar set to full soft ... right hand turns are fine as the driving wheel is under load ... i believe more rear spring is the answer, but that also means a complete new shock setup as well. ($$$) ... i was toying with the idea of adding a rear bar instead which should be good for about 30lbs of additional rear spring ... ah craps, will this ever end? (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) Andy |
nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
andy, having seen you drive the car at marina, you have a tendency to throw the weight around pretty damn radically -- and you've got the tires to support this. that said, you know your suspension is in tatters. let's see: you've got big-ass cantilever slicks with no front shocks to speak of, and your progressive springs probably START their compression around 100#s...
you can put adjustable collars with 2.5x10" race springs on your bilsteins. i'm running them. if i were you, i'd go straight to 225 or even 250#s -- you've got more than enough front bar to dial out any oversteer this would cause. you've got the makings of a DAMN FAST car, andy. i can't believe how well those slicks stick. once you get it dialed in, you will be SCARY. |
SirAndy |
some people believe i already am ... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) the 180 progressives start out as 140lbs (measured them friday at HPH). but then i remembered a trick from my old dirt bike days (anyone remember Hondas Pro-Link progressive setup?). we used to run the springs upside-down on the dirt bike which made them harder, did the same on my car friday and it worked. they feel stiffer now (closer to 180 i guess) and the understeer was almost gone. i guess i could just run the threaded colars and 225lbs springs on my bilsteins ... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
I'd try a rear bar first.
My car *never* spins the wheels and is flat as can be. I'm running 200# rears on Koni yellow. My car has more power, too. ( not that it matters, apparently ) (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) KT |
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/sheeplove.gif) I agree |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Much to my disgust, I lifted the inside rear at Mather....on concrete, but only in one turn.
300lb rears. Trekkor: You're not lifting the inside rear cause you're not generating enuff grip. I'm not trying to be mean, but your tires are shit. You can't expect to go as fast as your buddies that have gud tires. |
Joe Ricard |
Just for reference once again.
150 lb coil over with spring rubber inbetween one coil. No rear bar. Koni Adjustables@ 1/2 Front is stock torsion bars with Koni adjustables @1/4 22mm sway bar 1" from end. 205/50 -15 A compound Hoosiers on 8" rims 31 PSI With 4 1/2 inch back space. (the track width is massive) Result is pretty darn nuetral and ass loads of grip |
ArtechnikA |
when you are a serious contender for TToD at every event you enter, it will be close to ending. it's just maintenance after that point. |
Lo-Fi Version | Time is now: 7th July 2025 - 04:13 AM |
