> Front Fresh Air, Removing; how can water be directed .
jim_hoyland
post Jun 22 2018, 06:16 PM
Get that VIN ?
After removing the fresh air bower assembly, i’m Curious what has been done to direct the water that comes through the grill.
It looks like the frame that held the fresh air box could support a metal pan with a hose connected to drain the water away
Anyone made something like this .
Replies(1 - 7)
Rand
post Jun 22 2018, 06:20 PM
Cross Member
QUOTE(jim_hoyland @ Jun 22 2018, 04:16 PM) *
JoeO (Series9) built a custom tray under with a drain. I remember it from the RS build, but that was many years ago.
Dave_Darling
post Jun 22 2018, 07:52 PM
914 Idiot
IIRC, the box has two drains in the front corners. That's how the water is supposed to drain out.
--DD
jim_hoyland
post Jun 22 2018, 08:27 PM
Get that VIN ?
QUOTE(Rand @ Jun 22 2018, 05:20 PM) *
That’s what i’d Like to see....,,
jim_hoyland
post Jun 22 2018, 08:30 PM
Get that VIN ?
Found it, he posted a pic back in 2005. Said he TIG welded it
PlaysWithCars
post Jun 22 2018, 09:46 PM
I removed the motor and fan assembly from mine, because that's the vast majority of the weight, and seal the hole with a thin gauge aluminum plate. Then put the original plastic assembly back in place. Saved a lot of weight, didn't cost hardly anything, and no leaks.
GaroldShaffer
post Jun 22 2018, 10:27 PM
You bought another 914?
QUOTE(plays with cars @ Jun 22 2018, 10:46 PM) *
(IMG:style_emoticons/default/smilie_pokal.gif) Same plan I have to do to my AX car.
jim_hoyland
post Jun 23 2018, 05:24 AM
Get that VIN ?
QUOTE(plays with cars @ Jun 22 2018, 08:46 PM) *
Good Idea (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 16th June 2024 - 08:26 PM
