front spindle/hub/bearing |
JFG |
Jun 28 2018, 04:41 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I stripped and relubed one front side yesterday. I'm on the passenger side today and have found something is not right.
The retaining washer has worn on approximately 50% of the outer edge. Is there a specific reason that this happens. The bearings are unmarked and spin freely and the races are also good. Could the spindle / hub be bent? |
iankarr |
Jun 28 2018, 06:44 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Could be that damage was done a while ago, before the current bearing was installed. Looks more like something was rubbing between the center cap and that wdge
914Sixer |
Jun 28 2018, 06:47 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Might be from previous damage since there is no name on the bearing. Previous bearing collapsed in another rotor and they reused the washer?
Mark Henry |
Jun 28 2018, 07:32 AM
Might be from previous damage since there is no name on the bearing. Previous bearing collapsed in another rotor and they reused the washer? (IMG:style_emoticons/default/agree.gif) that would be my guess as well. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:11 PM |
