rosenfe |
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None ![]() |
My trim has come loose on the top at union and at the bottom strip and at 90. I see the tabs the trim fits into.I have crimped them a bit to make a tighter fit,but I may be missing a tab on the bottom of window. Can the tab be replaced with window in?Im assuming there is a hole in body for tab to insert。Is this correct?Anything else I can do to secure trim?Adhesive etc
Coastal6 |
Newbie ![]() Group: Members Posts: 47 Joined: 15-March 10 From: Florence, OR Member No.: 11,467 Region Association: Pacific Northwest ![]() |
Yep.. you are correct. There is a small hole in the windshield frame that the plastic clip snaps into. Don’t think there is any way to replace the clip with the windshield installed.
Super glue ? |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
i would say it depends on the gap. you might be able to put a new clip in. the new clip will have a pin sticking out, if you pull that, press the clip in place and then press the pin into the clip, as it slides in press it all the way in it will expand the back side of the clip and lock it in to place.
rosenfe |
If my clips do not hold trim securely and I don’t want to take window out,would useing an adhesive such as 3m window adhesive to the chrome be a no no?
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I would avoid super glue, You can use 3M weatherstrip adhesive. They also make butyl strips that can be used to hold stuff down. The idea is something that will not react with the paint and still hold it in place. Check at your local automotive paint supply store.
DRPHIL914 |
I would avoid super glue, You can use 3M weatherstrip adhesive. They also make butyl strips that can be used to hold stuff down. The idea is something that will not react with the paint and still hold it in place. Check at your local automotive paint supply store. that is a good tip. |
rosenfe |
Thanks
rosenfe |
I was going to use 3m window weld .The chrome piece would be glued to glass not body.Window weld is used to glue window to body.
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
no way without the windshield removed, one should always replace the clips when the windshield is out to make sure that the chrome strips stay in place.
Really the only thing you can do now is put some black silicone under the strip and tape it down until it dries My trim has come loose on the top at union and at the bottom strip and at 90. I see the tabs the trim fits into.I have crimped them a bit to make a tighter fit,but I may be missing a tab on the bottom of window. Can the tab be replaced with window in?Im assuming there is a hole in body for tab to insert。Is this correct?Anything else I can do to secure trim?Adhesive etc |
Lo-Fi Version | Time is now: 10th June 2024 - 07:27 AM |
