For once Left works / Right does not, My Blinking Switch is FUBAR |
forrestkhaag |
Jul 22 2018, 04:54 PM
Does anyone know what is causing my 71 turn signal switch to function perfectly on the left turn position - switching action and the release action / verses the right turn indicator which will blink if held near the "on-blinker" position but does not blink if pushed into the "on-blinker" position completely.
Left is good / right is not so good............ And is this condition fixable or is a new/old switch the fix? (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
Larmo63 |
Jul 22 2018, 05:10 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Forrest Bump.
worn |
Jul 22 2018, 05:34 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
worn |
Jul 22 2018, 05:35 PM
Does anyone know what is causing my 71 turn signal switch to function perfectly on the left turn position - switching action and the release action / verses the right turn indicator which will blink if held near the "on-blinker" position but does not blink if pushed into the "on-blinker" position completely. Left is good / right is not so good............ And is this condition fixable or is a new/old switch the fix? (IMG:style_emoticons/default/beerchug.gif) I have to think the problem is in the switch, since you can get things to work if you hold it right. Worn plastic or dirty contacts. |
forrestkhaag |
Jul 23 2018, 07:39 PM
I will check that out. As with most things 914, its a crap shoot to figure out...... Larmo rolls a 7 mostly on the come out every time. Winner Winner, Chic n' dinner..........
r_towle |
Jul 23 2018, 07:51 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Remove the horn button
The switch is one level down from what you are looking at. There is a plastic piece that pushes up or down when you Put it in the left or right position You broke that. I believe you can buy the 924 switch and that can be used As a replacement or buy used. |
r_towle |
Jul 23 2018, 07:52 PM
I am assuming you checked the fuses you hit with your foot?
bdstone914 |
Jul 24 2018, 07:48 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Sounds like a loose nut in front of the steering wheel.
(IMG:style_emoticons/default/smile.gif) |
bdstone914 |
Jul 24 2018, 07:50 AM
Forrest Bump. Where can I get one of these mechanics in a box? Sweet! I need a set of those for the customers that call me wanting a figure out their electrical problems over the phone. Or "...it is making a funny sound , What it is?" |
Ed_Turbo |
Jul 24 2018, 09:29 AM
Member Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
It is called old bro. Likely something electrical because I get some wierd electrical issues like the fuel gauge night light not turning on and in this case turn signal lever not blinking. I bought a new turn signal lever and the thing still isnt 100% perfect.
Comes to show how spoiled and reliable cars are today. (IMG:style_emoticons/default/driving.gif) -Ed |
forrestkhaag |
Jul 24 2018, 10:32 AM
Could not agree more with Ed / and Bruce. These cars are getting older faster. The trick is to out live the damned thing. So far I am running neck and neck.......
I appreciate the advice and will check out the several pontifications on the cause of my blinking issue. (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
Dave_Darling |
Jul 24 2018, 11:22 AM
I have also seen poor connections at the bulb sockets or bulbs cause weird turn signal problems, too...
--DD |
dr914@autoatlanta.com |
Jul 24 2018, 11:25 AM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
switch is worn, but try to clean the contacts after removing the steering wheel. YOUR switch is the biggest hassle in the world to replace so you do not want to unless absolutely necessary. Every time we sell one of the 70 71 switches, we feel sorry for the recipient, who has to replace it.
forrestkhaag |
Jul 24 2018, 12:27 PM
Thanks George / I have heard similar tales of woe related to a r&I......... (IMG:style_emoticons/default/sheeplove.gif)
Larmo63 |
Jul 24 2018, 09:46 PM
Lo-Fi Version | Time is now: 10th June 2024 - 03:22 AM |
