944 Front brakes .. ? |
Beakster |
Jul 22 2018, 09:40 PM
Member Group: Members Posts: 121 Joined: 13-August 15 From: Calgary,AB Canada Member No.: 19,055 Region Association: None |
Has anyone tried putting a set of 944 front brakes and rotters on a 914 ?? would that work ??
steuspeed |
Jul 22 2018, 10:02 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
mgp4591 |
Jul 23 2018, 12:35 AM
914 Guru Group: Members Posts: 5,380 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Has anyone tried putting a set of 944 front brakes and rotters on a 914 ?? would that work ?? Do you already have a 5 lug conversion? And if you do, is it a redrill of the 4 lug or is it a 911 front end? Also, do you know if you've got the 3" front struts or the 3-1/2" struts for the brake calipers? All of these points matter. |
Steve |
Jul 23 2018, 07:41 AM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I ran the 4 piston caliper 944 front brakes on my 911 3.5” struts. You have to oblong one of the holes to get it to fit. Worked great, but I couldn’t get them to stop squeaking, so I switched to Boxster brakes with the rich Johnson kit.
bdstone914 |
Jul 23 2018, 08:46 AM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Has anyone tried putting a set of 944 front brakes and rotters on a 914 ?? would that work ?? 1st question, Why? Do you need that much more braking? How is the car used ? Street or track? It is a system you are changing and all affected components including struts, hubs, etc. need to be considered. What rear brakes and master cylinder? 2nd question , which 944 brakes ? Are you referring to the 4 piston 944 Turbo Brembo calipers or the steel 944 calipers? Many different sizes of the turbo calipers between front and rear, and year they are from. Yes the turbos calipers can be installed on a 3.5" 911 front end. They are a 3.7" C-C on the bolt holes. They can be milled to fit 3.5. Bruce |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:49 AM |
