D Jet fuel lines... |
MikeM |
Jul 25 2018, 07:21 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...74 2.0 liter with Djet...
What size are the fuel lines in the engine compartment that connect to the fuel rails? Need to replace a couple... Thanks |
76-914 |
Jul 25 2018, 10:58 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
IIRC, 8mm connecting the 2 fuel rails together *mm from pressure reg to return line and 7mm from fuel rail to injector. (IMG:style_emoticons/default/beerchug.gif) I've had wine tonight and might be prone to error. (IMG:style_emoticons/default/beerchug.gif)
914Sixer |
Jul 26 2018, 07:17 AM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Make sure you do NOT used the braided hose UNLESS you are going for 100% original. Porsche replaced them on the fuel line recall. Use modern fuel line.
TheCabinetmaker |
Jul 26 2018, 07:22 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
What Mark said. It should be ethanol rated too!
JeffBowlsby |
Jul 26 2018, 08:03 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
We could tell you the size but why don’t you just measure the fuel rail OD yourself?
The fuel rails are 100% accessible to measure without taking anything apart. Attached image(s) |
MikeM |
Jul 26 2018, 10:08 AM
Because I don't have it apart. But thanks for your helpful comment.
Mark Henry |
Jul 26 2018, 12:14 PM
5/16" SAE 30R9 FI hose.
Bartlett 914 |
Jul 26 2018, 12:22 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
5/16" SAE 30R9 FI hose. (IMG:style_emoticons/default/agree.gif) The FI hose is important. It is rated for higher pressure. Standard hose can work but you are taking a gamble. |
Lo-Fi Version | Time is now: 10th June 2024 - 07:19 AM |
