74 Porsche 914 Light Issues |
9144me2enjoy |
Jul 26 2018, 10:07 PM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
Working on a 1974 Porsche 914, when you turn the headlights on, the front headlights work fine but not tail lights! The back up light on the right side, inner light comes on and the right front running light comes on. The right rear light on far right comes on but its dim. I’ve checked and made sure the trans is in Neutral not reverse. Suggestions, thanks for any help.
9144me2enjoy |
Jul 26 2018, 10:08 PM
Pics
Chris914n6 |
Jul 26 2018, 10:30 PM
Jackstands are my life. Group: Members Posts: 3,341 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Undo the 4 nuts and pull the housing out so you can flip it over. Then put the connectors where they need to be. Each terminal is labeled and wiring diagrams are easy to find.
9144me2enjoy |
Jul 26 2018, 10:37 PM
Undo the 4 nuts and pull the housing out so you can flip it over. Then put the connectors where they need to be. Each terminal is labeled and wiring diagrams are easy to find. I did that, it apppears when it came back from the body shop they had hooked the wires up improperly. After changing them back per diagram, all lights are working except the left side running lights. I’m not getting power to the rear lights #5 pole. I found I had a blown fuse, tomorrow I will see if I caint track down the bad wire causing the fuse to blow. Thanks |
914Sixer |
Jul 27 2018, 06:31 AM
914 Guru Group: Members Posts: 8,908 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Judging front the brightness of one or more lights and how dim the other is, you have a short or ground. Make sure you have the right bulbs in the base right.
dr914@autoatlanta.com |
Jul 27 2018, 08:11 AM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
to begin with you have a loose or blown fuse that is why the left running lights do not work, secondly, you should check the tail light wiring sequence (there is of course a good explanation in the Tech Tips 700 book, and finally make sure that the grounds behind the left engine compartment firewall relay board are clean and tightly connected
by the way, to get license from Porsche, I had to put vw-porsche 914 on the front cover!!!! |
9144me2enjoy |
Jul 27 2018, 10:48 PM
Figured all the lights out, thanks again for all your help! (IMG:style_emoticons/default/driving.gif)
Lo-Fi Version | Time is now: 13th June 2024 - 01:59 PM |
