CV joint question, how hard is it to replace the boot and flange ? |
DRPHIL914 |
Jul 31 2018, 07:03 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I replaced my CV shafts and joints a few years ago(thanks Chris Foley) but realized that the inner flange that the bolts go thru to attach to transmission have 6 holes not 4, so I had grease flying out of those extra holes. Well, now that the bottom of my car has been cleaned up and repainted I really don't want to be making that mess.
so my question is, would it be better to pull the CV and replace the flange with proper 4 hole ones( I bought NOS ones from 914sixer a few months ago), or just plug these holes somehow? This needs to be done before I put the motor back in the car and bolt up those CV's again this weekend. Thanks, Dr. Phil |
mepstein |
Jul 31 2018, 07:34 AM
914-6 GT in waiting Group: Members Posts: 19,312 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
It would be easy to do it now and since you already have them...
DRPHIL914 |
Jul 31 2018, 08:36 AM
Optimusglen |
Jul 31 2018, 08:44 AM
Senior Member Group: Members Posts: 912 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
The CV needs to be removed from the shaft for the new boot/flange to be installed. There'll be a circlip on the end of the shaft holding the joint on. Keep track of what direction the spring washer under the joint goes.
Here's a good video. http://www.youtube.com/watch?v=LsytyVzokBg and part 2 http://www.youtube.com/watch?v=KOma2BMhrzc |
Krieger |
Jul 31 2018, 09:52 AM
Advanced Member Group: Members Posts: 4,724 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
When I assembled mine many years ago I realized this would be a problem. I filled the holes in the CV joint with permatex. It worked very well. I don't remember which kind. I wonder how much grease you may have lost though.
DRPHIL914 |
Jul 31 2018, 10:07 AM
The CV needs to be removed from the shaft for the new boot/flange to be installed. There'll be a circlip on the end of the shaft holding the joint on. Keep track of what direction the spring washer under the joint goes. Here's a good video. http://www.youtube.com/watch?v=LsytyVzokBg and part 2 http://www.youtube.com/watch?v=KOma2BMhrzc thanks, that is helpful, i had pulled up the factory diagram to see the clip, i am sure i lost some grease it was a mess- before pulling the motor last year to send the car to paint i found some plastic plugs that fit pretty tight and that cut down on loosing more grease but i knkew that was a temporary fix at best. the new (NOS)flanges only have the 4 holes . so when i take these off i can inspect cv for wear , replace repack with grease. |
Lo-Fi Version | Time is now: 5th June 2024 - 12:33 PM |
