Intermittent Miss, Need Diagnostic Help |
Jackba |
Jul 31 2018, 03:40 PM
Newbie Group: Members Posts: 40 Joined: 13-July 18 From: Sacramento Member No.: 22,308 Region Association: Northern California |
All,
Looking for some diagnostic assistance for my stock '74 2.0 with FI. I was driving back to the Truckee area from Reno on Sunday and the car began stuttering. It happened for a quarter mile or so then stopped. I took it easy the last 20 miles. It was a very hot day. I left Truckee for Sacramento this morning and the car ran great until I got within 25 miles of home when it started missing/stuttering again. It is also very hot in Sacramento. I've never had this experience in the 5 years since I've owned this car. I always try and drive it in cooler weather but there was a Porsche event in Reno I wanted to attend this past Sunday. Any ideas? Thanks, Jack |
jim_hoyland |
Jul 31 2018, 04:05 PM
Get that VIN ? Group: Members Posts: 9,308 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Need some details about the motor, fuel delivery, ignition. And, what was the last repair or service ?
Jackba |
Jul 31 2018, 04:17 PM
Need some details about the motor, fuel delivery, ignition. And, what was the last repair or service ? Jim, Car is stock with original FI (FI harness refreshed and tested by the expert on this site), 50,000 mile 2.0 engine last serviced within 600 miles, rebuilt injectors. Ignition is stock with new wires, coil, points, plugs. New fuel filter. Original fuel pump located in its stock location. Issue occurred after driving an hour in hot weather. |
Jackba |
Jul 31 2018, 04:52 PM
One additional point: while the engine was missing/hesitating I glanced at the volt meter and it held steady.
Jack |
Big Len |
Jul 31 2018, 05:37 PM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
Was the miss during acceleration, deceleration or steady throttle?
Jackba |
Jul 31 2018, 05:58 PM
Both steady and acceleration, going up a hill.
Jackba |
Jul 31 2018, 06:59 PM
I just discovered that the seal between the engine tin and the body pulled away from the body on the passenger side. Obviously heat from the exchangers can escape into the engine compartment due to the opening. The fuel lines (stainless) are directly above the unsealed area. Could the problem have been vapor lock?
oakdalecurtis |
Jul 31 2018, 07:51 PM
Oakdalecurtis Group: Members Posts: 1,327 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I just discovered that the seal between the engine tin and the body pulled away from the body on the passenger side. Obviously heat from the exchangers can escape into the engine compartment due to the opening. The fuel lines (stainless) are directly above the unsealed area. Could the problem have been vapor lock? My 76 2.0 had a similar intermitent miss. Could be a lot of things, but when I pulled the dizzy to check the FI trigger points, I found a small piece of debri behind one of the point arms which moved randomly and jammed the arm. Once the debri was removed the engine has run perfectly ever since. (IMG:style_emoticons/default/beerchug.gif) |
r_towle |
Jul 31 2018, 08:45 PM
Custom Member Group: Members Posts: 24,579 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Jackba |
Jul 31 2018, 09:05 PM
No. I haven't. Thanks for this this link. I'll get on it.
Jack |
Lo-Fi Version | Time is now: 23rd May 2024 - 10:23 AM |
