Almost a new engine, Update! |
PanelBilly |
Aug 3 2018, 04:15 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
PanelBilly |
Aug 13 2018, 04:24 PM
worn |
Aug 13 2018, 04:30 PM
can't remember Group: Members Posts: 3,163 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
KELTY360 |
Aug 13 2018, 05:26 PM
914 Neferati Group: Members Posts: 5,036 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
sixnotfour |
Aug 13 2018, 05:32 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
righty IN lefty Out
jcd914 |
Aug 13 2018, 06:35 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Hopefully it will be done this week Good luck. Pretty motor. While we have the photo, can anyone tell me what kind of bayonet hose fits on the engine vent? The tube with the two small brass studs at top. Stock, the breather hose is just cloth woven rubber hose held on with a clamp. The two "small brass studs" are there so the hose can't slide off when clamped. Jim |
PanelBilly |
Aug 14 2018, 12:43 PM
I use a hose I got from a local hose and fitting supplier. It’s grey so it doesn’t look OEM but it’s not effected by the oil gasses that pass thru it. I’ve heard that the factory style hoses degrade over time and gets loose where it connects to the engine.
Luke M |
Aug 15 2018, 02:11 PM
Senior Member Group: Members Posts: 1,377 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
You may recall that a backwards gear caused all kinds of damage to my engine So its coming back together now. I'm waiting on 2 rings that were broken, but here it is with the new cylinders and pistons I had to take a double take at the piston pic. Are you sure the pistons are on the correct way? Not sure if it's the pic but it looks like the piston in # 2 cylinder is ex pocket up? Got a better pic to verify ? |
PanelBilly |
Aug 17 2018, 10:48 PM
PanelBilly |
Aug 23 2018, 06:43 PM
porschetub |
Aug 23 2018, 10:15 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
It's getting closer. I blocked off the oil pressure sender for the gauge at the front of the engine and got a sender for the top location with two leads. One is for the green light. The sender in the front was prone to leaking. Sorry to be pain but what was the cause of your issues,was it miss aligned chain sprockets off the cams ??,couldn't tell from the pic . Good move on the sender,they work well,less crap hanging of the case in my situation and one less leak,worst overheat issue was 12psi for me @ idle,the switch on mine comes on @ 10psi tested. Cheers. |
Larmo63 |
Aug 23 2018, 10:41 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Man, I'm so sorry this happened to your beautiful build.
The devil is in the details. Can you explain what happened completely? What were the symptoms leading up to the Big Bang? Thanks |
PanelBilly |
Aug 25 2018, 02:45 PM
Man, I'm so sorry this happened to your beautiful build. The devil is in the details. Can you explain what happened completely? What were the symptoms leading up to the Big Bang? Thanks No bang. I was having the engine resealed and found the damage from the case being worn from the gear and chain. No damage to the crank, mains,or oil pump but the metal managed to get just about everywhere else |
PanelBilly |
Aug 28 2018, 10:26 PM
It’s back in the car and I heard it run today. One of the wires on the alternator shorted out so I helped pull it out and my mechanic took it to the shop next door where the fix them. Should be back together tomorrow
Sounded great |
Cairo94507 |
Aug 29 2018, 06:29 AM
Michael Group: Members Posts: 9,822 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
EdwardBlume |
Aug 29 2018, 06:37 AM
(IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
all it takes is time and money |
tomeric914 |
Aug 30 2018, 07:24 AM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Great to hear it's back together and running PB! Sorry to hear of your troubles. (IMG:style_emoticons/default/sad.gif)
Tdskip |
Aug 30 2018, 07:26 AM
Good to hear!
PanelBilly |
Aug 30 2018, 09:25 PM
Went by the shop today and its done. I was on my way to Portland so I’m not bringing it home till Tuesday. Can’t wait!
Lo-Fi Version | Time is now: 8th June 2024 - 05:26 PM |
