Console Gauge Wire Harness Conversiom, Quick and easy |
914Sixer |
Aug 7 2018, 04:44 PM
914 Guru Group: Members Posts: 8,887 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I am not using stock gauges. I made up some custom ones. Using oil pressure, oil temp and volt gauges. You simply take the clock wiring and make it your wiring for the oil pressure gauge. The black wire becomes your gauge wire, brown stays as ground. Take a jumper wire (I had old cut up harness and used plug) and make wire to run from volt + to positive on volt gauge to + on the oil pressure gauge. I used the old plug end to protect wires like on the oil temp gauge. Wire ends do not have locking clip but can be pushed on with needle nose pliers. To connect to the positive on the the volt gauge I used a piggyback connector.
Last step is I added LED bulbs, big difference. Attached image(s) |
dr914@autoatlanta.com |
Aug 7 2018, 05:11 PM
914 Guru Group: Members Posts: 7,872 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Jeff makes an excellent console wiring harness.
914Sixer |
Aug 7 2018, 06:25 PM
Jeff's for stock set up.
Front yard mechanic |
Aug 7 2018, 06:29 PM
Senior Member Group: Members Posts: 1,165 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Nice set up (IMG:style_emoticons/default/flag.gif)
bdstone914 |
Aug 7 2018, 08:27 PM
bdstone914 Group: Members Posts: 4,524 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
How are you running a oil pressure wire to the engine? Or are you using the low pressure warning wire as the oil pressure wire ?
Nice setup. I have a bunch of those old VDO gauges that I think look much better than the console gauges. And who needs a clock anyways ? |
Lo-Fi Version | Time is now: 23rd May 2024 - 10:38 AM |
