Friday, 15 August 2025
> Gas smell inside?
dgraves
post Aug 15 2018, 05:57 PM
After sitting overnight with the windows up I recently detected a faint gas smell inside the car. Everything looks dry topside in the front trunk, nothing wet or excessively gassy under the dash, and under the car is dry. Any ideas where to look? I have no idea if the gas line has ever been replaced and wouldn't know how to do it. Any suggestions would be great.
Loving my summer daily driver in Montana.
Replies(1 - 8)
Shadowfax
post Aug 15 2018, 06:08 PM
Show us the meaning of haste
Probably time to replace the plastic fuel lines in the tunnel and also any soft fuel lines in the engine bay and on the fuel tank. Also check the gas cap gasket. I got stainless lines for the tunnel from Tangerine Racing.
wndsrfr
post Aug 15 2018, 07:06 PM
Gas cap gasket likely dried out....very common.
post Aug 15 2018, 07:16 PM
914-6 GT in waiting
QUOTE(wndsrfr @ Aug 15 2018, 09:06 PM) *
Good place to start. Easiest and cheapest.
Coondog
post Aug 15 2018, 09:34 PM
Be safe, change every fuel line, and gasket
dgraves
post Aug 15 2018, 09:57 PM
QUOTE(Coondog @ Aug 15 2018, 09:34 PM) *
Thanks, everyone. Much appreciated. I'll check the gasket first. How difficult to change out the fuel line through the tunnel. This is new territory for me.
maf914
post Aug 16 2018, 05:49 AM
Not a Guru!
QUOTE(wndsrfr @ Aug 15 2018, 05:06 PM) *
Check the gas cap. Then check that the filler neck/vapor expansion tank assembly on top of the fuel tank is tightly bolted to the tank. I have had gas seep from this area on my 76 in the past. The small hex head bolts holding this can be tough to access. Thin wall sockets will help.
Mikey914
post Aug 16 2018, 10:13 PM
The rubber man
Surprisingly its more probable its a rubber line yhan the plastic.with the ethanol in the fuel being increased I had fuel lunes (rubber) fail on 2 cars this year.
post Aug 17 2018, 08:19 AM
QUOTE(Mikey914 @ Aug 16 2018, 09:13 PM) *
- Lo-Fi Version Time is now: 14th August 2025 - 08:09 PM
