No power at pin 13 for fuel pump |
carking1996 |
Aug 22 2018, 02:40 PM
Member Group: Members Posts: 69 Joined: 15-September 16 From: Ohio Member No.: 20,399 Region Association: North East States |
So trying to get these electrical issues fixed, I'm trying to use the original black red wire from the relay board for the fuel pump. I've got a ground connected to the proper place as shown in a lot of discussions/tech articles. But I have no power at pin 13. Any causes for this? Relay is good, everything seems like it should work, just no power at that pin with the key on (or off of course).
BeatNavy |
Aug 22 2018, 04:01 PM
So trying to get these electrical issues fixed, I'm trying to use the original black red wire from the relay board for the fuel pump. I've got a ground connected to the proper place as shown in a lot of discussions/tech articles. But I have no power at pin 13. Any causes for this? Relay is good, everything seems like it should work, just no power at that pin with the key on (or off of course). If you've done the proper troubleshooting procedures then it most likely points to a relay board trace fault. Check continuity from where pin 13 connects on relay board to pin 87 on relay 75 (fuel pump relay). A while back I recreated Paul "Brad" Anders fuel pump troubleshooting procedures into a PowerPoint presentation (because it was offline, and I had a printed copy). PM me with your email address and I can send you a copy (PDF or otherwise). |
carking1996 |
Aug 23 2018, 06:45 AM
If you've done the proper troubleshooting procedures then it most likely points to a relay board trace fault. Check continuity from where pin 13 connects on relay board to pin 87 on relay 75 (fuel pump relay). A while back I recreated Paul "Brad" Anders fuel pump troubleshooting procedures into a PowerPoint presentation (because it was offline, and I had a printed copy). PM me with your email address and I can send you a copy (PDF or otherwise). I will give that a go and if it doesn't work, I'll get a new relay board. |
Shadowfax |
Aug 23 2018, 06:56 AM
Show us the meaning of haste Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States |
What year is your car? I had a similar issue on my ‘74. It was the seatbelt interlock relay. Jeff Bowlsby has a post showing how to jumper the wires and bypass the relay.
carking1996 |
Aug 23 2018, 07:22 AM
What year is your car? I had a similar issue on my ‘74. It was the seatbelt interlock relay. Jeff Bowlsby has a post showing how to jumper the wires and bypass the relay. It's a 75. Seeing as everything else on the board seems okay, I'm not sure it's the relay board yet. I'll do a search for that seatbelt interlock relay bypass. |
dr914@autoatlanta.com |
Aug 23 2018, 07:23 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
1.8 or 1.7 2.0 engine and injection system?
So trying to get these electrical issues fixed, I'm trying to use the original black red wire from the relay board for the fuel pump. I've got a ground connected to the proper place as shown in a lot of discussions/tech articles. But I have no power at pin 13. Any causes for this? Relay is good, everything seems like it should work, just no power at that pin with the key on (or off of course). |
carking1996 |
Aug 23 2018, 07:30 AM
It's a 2.0. It has carbs, but the PO wired the fuel pump directly to a fuse (the one for the cluster and other things under the dash) to keep it on with the ignition. I'm trying to use the original black/red wire instead.
Aug 23 2018, 07:41 AM
ok that clarifies, you can put a jumper in the fuel pump relay receptacle, jump the 7 to the 11 pin. I can clarify later
It's a 2.0. It has carbs, but the PO wired the fuel pump directly to a fuse (the one for the cluster and other things under the dash) to keep it on with the ignition. I'm trying to use the original black/red wire instead. |
carking1996 |
Aug 23 2018, 11:30 AM
So. Turns out I'm not getting power at the pump relay either. Bad board?
Aug 23 2018, 11:44 AM
power to the board is provided through the red wire on pin 14 that attaches to the battery positive post, then goes through the fuel pump fuse a 25 amp in the rear position of the relay board (rear of the car)
So. Turns out I'm not getting power at the pump relay either. Bad board? |
carking1996 |
Aug 23 2018, 11:52 AM
Yes the board is getting power for sure. Not hearing the fuel pump relay click. So it has no power. Unsure why.
Lo-Fi Version | Time is now: 1st June 2024 - 05:08 PM |
