intermittent starter not turning issue |
rosenfe |
Aug 27 2018, 10:33 AM
Senior Member Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
On my 74 2.0,when turning key ,power turns on,red and green lights come on,but starter will not turn.Jumping starter directly engages starter and it will continue to engage starter for a day or so and then no engagement.Car is in good shape,wires to starter look good and are tight.
Any suggestions.would this be a good candidate for mark henry relay?.Battery is good,starter works well. |
North Coast Jim |
Aug 27 2018, 10:37 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Had the very same issue after a complete rebuild of the car. It wasn't a hot start issue sometimes it just wouldn't start. New red top battery checked good.
Found Mark Henry's relay addition and all is well since. Can't hurt either unless your a concours car. Do it !! |
Triaddave |
Aug 27 2018, 10:55 AM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
The same problem on my 75 car, turned out to be ignition switch where key goes in. It was a $40.00 ish part. The steering wheel,turn/wiper stuff all comes out,cir-clip too all to get to the hidden screw. not as hard as it sounds. it fixed my car in about 1/2 hour
Mark Henry |
Aug 27 2018, 11:01 AM
The stock bosch solenoid needs a full 9v to kick in, likely due to old wiring, corrosion, resistance you're not getting a full 9v.
Likely my fix will solve the issue, but you should still clean all your grounds, terminals, connections, etc. Link at the bottom of my signature. |
rosenfe |
Aug 27 2018, 11:27 AM
I will try relay first. Replacing switch is more work.I have done it several times.
rosenfe |
Aug 27 2018, 07:56 PM
My starter has 2 yellow wiires going to seperate Jacks. Mark Henry’s pics show onlyone yellow. Anyone know what to do with that second wire and hooking up relay
Lo-Fi Version | Time is now: 8th June 2024 - 10:17 AM |
