WTB Boxster trans backup switch connector |
dwillouby |
Aug 30 2018, 09:40 AM
Member Group: Members Posts: 393 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
Hello,
I need the plug in connector /wires to connect to the reverse switch on a 02 Boxster S trans. Anybody have one? Thanks David |
bdstone914 |
Aug 30 2018, 05:23 PM
bdstone914 Group: Members Posts: 4,529 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
dwillouby |
Aug 30 2018, 07:10 PM
Of Course...
They will sell the complete harness. Only need the connector. |
bdstone914 |
Aug 31 2018, 04:58 AM
Of Course... They will sell the complete harness. Only need the connector. Did you check with Porsche? Or download PET for free and go thru section 9 to see if they show the connector part number. Many connectors. Post a picture of th connector or switch. The connector is probably not made by Porsche and available elsewhere. Or post of Pelican Boxster forum. You can check with dismantlers too. |
yellowporky |
Aug 31 2018, 08:39 AM
Member Group: Members Posts: 427 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
I went through the same process a few years ago and finally found a website that sells the connectors, pins and boots. I will try to find the site and post it for you.
Chris |
timothy_nd28 |
Aug 31 2018, 09:22 AM
I'm totally in the same boat. I have tried several Porsche dismantlers, once they understand what connector I was after, they soon realize its a 5 dollar part and not worth the trouble on their end.
bdstone914 |
Aug 31 2018, 03:19 PM
Here is a pic of the switch Does no look like too unusual connector. Very similar to a fuel injector connector.
Try belmetric.com Attached image(s) |
bdstone914 |
Sep 1 2018, 05:20 PM
Attached image(s) |
davesprinkle |
Sep 1 2018, 08:19 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
That is a two-terminal connector made by AMP, PN 963040-3. It is part of the AMP Junior Power Timer line of connectors. It can be purchased at digikey.com, along with the crimp terminals. You'll need a crimp tool.
bdstone914 |
Sep 1 2018, 09:06 PM
That is a two-terminal connector made by AMP, PN 963040-3. It is part of the AMP Junior Power Timer line of connectors. It can be purchased at digikey.com, along with the crimp terminals. You'll need a crimp tool. Or buy it from O Reilly with wire leads installed for $6 . |
davesprinkle |
Sep 1 2018, 10:11 PM
That is a two-terminal connector made by AMP, PN 963040-3. It is part of the AMP Junior Power Timer line of connectors. It can be purchased at digikey.com, along with the crimp terminals. You'll need a crimp tool. Or buy it from O Reilly with wire leads installed for $6 . Yes. Disadvantage is that the pigtail approach requires a couple of ugly and unreliable butt-splices. And a crimp tool. |
bdstone914 |
Sep 2 2018, 10:43 AM
That is a two-terminal connector made by AMP, PN 963040-3. It is part of the AMP Junior Power Timer line of connectors. It can be purchased at digikey.com, along with the crimp terminals. You'll need a crimp tool. Or buy it from O Reilly with wire leads installed for $6 . Yes. Disadvantage is that the pigtail approach requires a couple of ugly and unreliable butt-splices. And a crimp tool. Or cut , soldier, shrink wrap the wires. |
dwillouby |
Sep 5 2018, 11:30 AM
Thanks,
Will stop by and pick one up. No problem connecting as have electronic engineering background. David |
ClayPerrine |
Sep 6 2018, 02:49 PM
Life's been good to me so far..... Group: Admin Posts: 15,498 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
That is a standard Bosch fuel injector plug. You can buy them as kits direct from Porsche.
I keep a full set of them in my parts stash. |
Lo-Fi Version | Time is now: 31st May 2024 - 07:18 PM |
