Broke my shifter coupler, any write ups to correctly R&R? |
Mueller |
Aug 31 2018, 01:10 PM
Luckily I have a brand new flex joint, I just don't want break it again.
bdstone914 |
Aug 31 2018, 01:31 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
ClayPerrine |
Aug 31 2018, 03:50 PM
Life's been good to me so far..... Group: Admin Posts: 15,514 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You can always replace it with a steering U-Joint. Easy to uncouple, and never requires new bushings.
Plus, what you need is probably already in your parts stash. |
Bartlett 914 |
Sep 1 2018, 10:24 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Luckily I have a brand new flex joint, I just don't want break it again. Call me at 951 536 seven for seven ate and I can walk you through the non destructive R & R. When driving out the pin, it is important that you don't drive against the aluminum. You must support the square part of the shift rod. Do not lay horizontal on the aluminum coupling. The pin is press fitted in the steel so this is where support must placed |
914forme |
Sep 1 2018, 11:05 AM
You can always replace it with a steering U-Joint. Easy to uncouple, and never requires new bushings. Plus, what you need is probably already in your parts stash. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 10:32 PM |
