Marv's3.6six |
Actual member 7" ![]() ![]() ![]() Group: Members Posts: 695 Joined: 22-November 04 From: Huntington Beach, Ca. Member No.: 3,165 Region Association: Southern California ![]() ![]() ![]() |
With all the mods I'm doing to my teener I am concerned about the class I will be running. The car was PCA zone 8 class HI at about 35 points, now with all the changes she will be up in the mid 50's somewhere between 52 & 56. Thats going from an "Improved class" to a "Modified" or even "R class" I would assume an R class is considered an all out racer, tube frame, non streetable, sky's the limit car etc.
I am hoping for a TTOD capable car, BUT who or what normally races "modified or R" class? Should I tone it down for going for class wins or throw caution to the wind? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Take it SD PCA AX and see if you can get close to the Dieter 914....
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
What "*" said.
Are you using the calssification sheet Zone 8 provides? If you're still unsure have a tech inspector help classify you. |
eeyore |
Senior Member ![]() ![]() ![]() Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None ![]() |
HMeeder is a tech guy for SDR.
In SDR this year, there was an average of 1 AR, 2 AM, 0 HI for sixes and 1 AI for fours. Go to http://group9motorsports.com/ and click the PCA link to sift through SDR standings. Steve Grosekemper (Dieter's) runs AR. Ususally TTOD. 2.7 six. Big flares with schlicks. Go for AM, and bump to AR with tires? If things work out real good for me in the next few months, I could be in HI / AM. |
Joe Bob |
Manfred is in HP....I used to run in HI with the 3.0 powered ROCKET. The Rock and I won the Zone 8 AX series in '99.
My 911 is HI as well....don't even wanna guess where Frank would get stuck... |
Marv's3.6six |
(IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) With all my dodads I'm at 55 points, without slicks! I guess what I am asking is there alot of peeps in zone 8 competing in AR? Who are they, besides Deiter?
Then my next question would be setup, who do you guys recommend for a top notch suspension setup and allignment? Preferably in Riverside or San Diego counties. Front susp components: Hollow front torsens, PMS Delrin bushings, weltmeister adjustable sway, custom valved RSR struts with 19mm raised spindles, decambered elephant ball joints, monoballs, turbo tie rods, PMS bump steer kit, Brembo GTP lightweight brakes Rear susp: body stiffener kit, beefed up inner susp mounts, boxed trailing arms, PMS delrin bushings, adjustable Konis, 190lb springs, PMS rear toe adjuster kit, Brembo GTPs Thanx...Marvo |
Joe Bob |
The SD website will give you all the race results in both AX and DE...in many cases the competitors have email links.
http://www.pcasdr.org/home/index.html |
eeyore |
Go to the PCA SDR Forum and ask this same question. Many of the regulars there compete outside of SDR and will know.
Lo-Fi Version | Time is now: 4th July 2025 - 08:15 PM |
