Momo Hub Adaptability?, Mystery Wheel Spacer too big |
RickS |
Sep 10 2018, 06:02 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Need the brain trusts noggins on whether this mystery wheel might bolt up to a Momo hub. The existing hub says Made in Italy but that’s it. Wheel has no identification but it has a fat grip and finger notches on the back. Love the ergonomics but the spaced on it is not designed for 6’2”. Car originally a 4
Thoughts? |
RickS |
Sep 10 2018, 06:03 PM
zig-n-zag |
Sep 11 2018, 04:26 AM
Member Group: Members Posts: 182 Joined: 18-May 06 From: Hawaii Member No.: 6,024 |
Sorta looks like a Le carra.
RickS |
Sep 11 2018, 11:33 AM
Took it to a machine shop which specializes in Formula Fords to see if they could cut down the rings and then reassemble. They said for $300 to $400 no problem. Yeah right. If no one knows I might just order a Momo hub and see if they match, that is if Momo still makes them.
jcd914 |
Sep 11 2018, 11:45 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
It looks like a Momo hub with an adapter attached to it.
Take the adapter off and measure the diameter and spacing of the mounting hole is the hub and post it. I can probably find my Momo hub this evening and measure it. Jim |
marksteinhilber |
Sep 11 2018, 12:13 PM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
I have a Momo hub that was drilled and tapped to fit a 5 screw wheel common in the US like Grant Wheels. I have also made adapter plates to fit a LeCarra wheel to a Momo hub and to then use the smaller diameter Momo style horn button. All way less than $200. the cast aluminum style Momo hub is very adaptable.
HerdofCrickets |
Sep 11 2018, 01:09 PM
Member Group: Members Posts: 68 Joined: 23-September 16 From: Overland Park, KS Member No.: 20,423 Region Association: None |
I have a Momo hub that was drilled and tapped to fit a 5 screw wheel common in the US like Grant Wheels. I have also made adapter plates to fit a LeCarra wheel to a Momo hub and to then use the smaller diameter Momo style horn button. All way less than $200. the cast aluminum style Momo hub is very adaptable. That wheel is awesome. Been looking to get a different steering wheel.... |
GregAmy |
Sep 11 2018, 01:18 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
If it uses the same bolt pattern as the Italian Luisi wheels, you can use this spacer to adapt it.
http://www.ompamerica.com/product_info.php...products_id/433 |
sixnotfour |
Sep 11 2018, 02:13 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
id be interested in the bigone
RickS |
Sep 11 2018, 10:23 PM
If it uses the same bolt pattern as the Italian Luisi wheels, you can use this spacer to adapt it. http://www.ompamerica.com/product_info.php...products_id/433 Thanks to all. I will check these out. |
RickS |
Sep 11 2018, 10:36 PM
It looks like a Momo hub with an adapter attached to it. Take the adapter off and measure the diameter and spacing of the mounting hole is the hub and post it. I can probably find my Momo hub this evening and measure it. Jim Dam. In Cali until Sunday or I could get the measurements. Will definitely do when I return to the Pac NW. |
Lo-Fi Version | Time is now: 7th June 2024 - 01:18 PM |
