Bob Wolcott |
Member ![]() ![]() Group: Members Posts: 85 Joined: 18-May 05 From: McMinnville, OR Member No.: 4,096 ![]() |
What is the best way to clean carbon from the valves and heads of a 911 engine?
Thanks, Bob |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
B12 carb clean and a light wire brush, or abrasive (bead) blasting(what the shops use)...
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
glass bead.....doesn't remove metal...just deposits |
xsboost90 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 ![]() |
take it out and run it hard...w/ some emissions cleaner in there, works every time..oh off the car. Soak it in cider. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Dr. Roger |
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California ![]() |
With the heads on or off the car? |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
I dunno bout air coolers... but we used to dump a gallon of hot soapy water down the hole on V8s with the pedal down pretty far...
POW! POW!~ exhaust sized chunks. M |
Dr. Roger |
Yep, done that. It's kinda' fun. When I was working as a "test fuel additive rater" in the Test Fuels Additive Lab at Chevron for a couple of years, I learned that the quickest "clean up" additives were the ones with the highest percentages of Techron/Techroline. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) There was a point of diminishing returns. Yes we did test other competitors additives but there was only one better than techron at that time. Amoco "Clear" was #1 back then. Only sold back east. Shifting gears.......... Glass beads are great as long as they are COMPLETELY removed from the heads once blasted. They have the potential of being very nasty if there are residual beads. The "One bottle and pass" stuff does work. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) My old '72 Chevelle appreciated it and so did I. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
spare time toys |
hooked on grilling food. ![]() ![]() ![]() ![]() Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region ![]() |
I use these pads made by 3M they have them in green and white. They are 2 in dia. and clean carbon and gaskets like crazy.
Attached image(s) ![]() |
spare time toys |
Before and after I have cleaned up 1 head in this shot
Lo-Fi Version | Time is now: 31st July 2025 - 06:14 PM |
