Easy Voltage readings, Plug into cigarette lighter |
tmc914 |
Sep 23 2018, 05:28 PM
Member Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States |
Here is a product found on Amazon that I just bought recently. It helped almost instantly. It gives you voltage readings and had a green light to indicate if all is okay. Starts blinking if voltage falls to low. Also has usb charger built into it for charging phones or maybe a GPS unit.
Installed this until I have time to install a "real" voltage gauge. Found voltage dropped way to much when I turned on fresh air fan (dropped to 10.1 volts). Yes, there is a problem with the fan wiring, have another post looking how to solve it on the board. Thought I smelled something burning. Turned off fan and voltage went right back up to 13.8 volts. The blinking light caught my eye right away. Might be even better that a voltage gauge. Only $12.99 plus tax. Don't normally stump for products but I think it was a post on this website that got me going in that direction a few weeks ago. |
steuspeed |
Sep 23 2018, 05:41 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Slick!
My stock gauge was showing about 10.5V. Had me a bit worried on my last drive. Not driving as much as I used to. Trying to keep the miles down. Everything seemed to be working fine. All lights at good levels. Got home and put a meter on the battery while engine at idle. 13.9V, so my gauge is off. |
VaccaRabite |
Sep 23 2018, 07:19 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Slick! My stock gauge was showing about 10.5V. Had me a bit worried on my last drive. Not driving as much as I used to. Trying to keep the miles down. Everything seemed to be working fine. All lights at good levels. Got home and put a meter on the battery while engine at idle. 13.9V, so my gauge is off. More likely you have resistance in the wires due to a bad ground somewhere and its showing less voltage. I don't think there is much calibration to do in a voltmeter. Zach |
McMark |
Sep 24 2018, 08:54 AM
It's a neat setup, but don't evaluate the performance of your electrical system. As Zach mentioned, the condition and size of the wires where your reading have a large effect on the number. While your cigarette lighter outlet might be reading 10.1, the reading at the battery is probably quite a bit higher. The reading at the fuse panel where the big red wires come in will also read higher.
The best volt gauge setup would use a 16g wire directly from the battery (or from the large red wire at the fuse panel), run through a relay (so you're not draining the battery 24/7). The more direct and isolated your volt gauge is, the more accurate it is. It is a cool setup thought to have two charges and a readout. (IMG:style_emoticons/default/thumb3d.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 07:14 PM |
