FS - 1974 914 2.0, $9000 OBO |
HarveyH |
Sep 28 2018, 12:22 PM
Member Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
Not a show car, but a nice Sunday Driver. I’ve had the car for over 20 years, and it has always been a fun summer driver. Until recently, the odometer has been inoperative but I’ve never driven it more than 500 miles in a year, and usually much less. Probably less than 5,000 miles since I bought it.
Harveyh914@comcast.net 610-269-1075 – Leave Message Also on Craigslist at https://philadelphia.craigslist.org/cto/d/1...6709825268.html The Good: • 2056 with cam and Webers • 2 Liter heads • Bilsteins • 914-6 rear springs (80 Lbs.???) • 19mm front bar with factory linkage • Stock 16mm rear bar • Recent (mileage wise) engine rebuild • Mahle wheels (5) • 1 Year old tires (Dunlop SP5000) • 1 Year old battery • Longitudinals and jack posts replaced • Crane Hi-6 multi-spark box with PS91 coil and Pertronix point replacement • Recent new alternator and solid state regulator • Relay board cleaned and all connection points soldered • SSI heat exchangers • LED running and instrument lights • Bronze pedal cluster bushings The Bad: • Engine shelf needs work (new Restoration Design panels included) • Older repaint, Guards over original Sunflower Yellow. Needs work • Recently repaired odometer shows 82900 but real mileage unknown (inoperative when I bought the car) • Old Bursch exhaust (solid but loud) Also Included: • Restoration Design panels for engine shelf repair and new battery shelf • Engman improved manual trunk release kit – never installed • Parts accumulation for under trunk external oil cooler • Parts accumulation for deep oil sump • Various parts for original fuel injection system. Brain, manifolds, throttle body, injectors with wiring harness, etc. • Original Porsche crest steering wheel (Aftermarket wrapping, don’t know what’s under it) • Repro 916 front bumper • Weltmeister short shift kit (Tried it, didn’t like it.) • Miscellaneous seals, gaskets, ignition parts, etc. • 20 years of magazine clippings • Haynes and Clymer Workshop Manuals • HP and Bob Tomlinson Weber Manuals |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:49 AM |
