Brain trust question for hydraulic clutch...., 944 turbo clutch pedal insanity..... |
second wind |
Oct 1 2018, 04:13 PM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hey guys.....please help if you can. Took 1989 944 turbo to Rennsport instead of 914....about 100 in the clutch pedal went down and never came back up. I used my toes to pry it back up and then pumped it to get a shift out of it. Made it to hotel and left parked for two days. Brake reservoir full but forced a bit more in. Somehow had a inch or so of pedal so made the best of it. Last 100 miles back the pedal starts working like perfect and pushes back up like normal. This is a puzzlement to me. Had new brake pads put in week prior and also clutch pedal acted a little funky a month earlier. Any ideas out there? Anyone know what power bleeding is? I would love to figure this out. Have read other forums and guys have replaced master and slave cylinders and still have the same problem. I sure would appreciate an explanation before burning through my money. Thank you very much.
gg |
markhoward |
Oct 1 2018, 05:06 PM
Member Group: Members Posts: 378 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California |
Heard this is a common problem and is often caused by corrosion in the master cylinder. Don't have first hand knowledge as its been 25 years since I had my 951 (need another). Was recently helping a friend who was having the same problem with her 944 s2 and found this site to be helpful. https://www.clarks-garage.com/
mb911 |
Oct 1 2018, 05:07 PM
914 Guru Group: Members Posts: 6,883 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Hey guys.....please help if you can. Took 1989 944 turbo to Rennsport instead of 914....about 100 in the clutch pedal went down and never came back up. I used my toes to pry it back up and then pumped it to get a shift out of it. Made it to hotel and left parked for two days. Brake reservoir full but forced a bit more in. Somehow had a inch or so of pedal so made the best of it. Last 100 miles back the pedal starts working like perfect and pushes back up like normal. This is a puzzlement to me. Had new brake pads put in week prior and also clutch pedal acted a little funky a month earlier. Any ideas out there? Anyone know what power bleeding is? I would love to figure this out. Have read other forums and guys have replaced master and slave cylinders and still have the same problem. I sure would appreciate an explanation before burning through my money. Thank you very much. gg Very typical of 944s that have sat or the slave or master cylinder are bad or need bleeding.. Moisture is the issue usually.. |
second wind |
Oct 1 2018, 08:45 PM
Hey guys.....please help if you can. Took 1989 944 turbo to Rennsport instead of 914....about 100 in the clutch pedal went down and never came back up. I used my toes to pry it back up and then pumped it to get a shift out of it. Made it to hotel and left parked for two days. Brake reservoir full but forced a bit more in. Somehow had a inch or so of pedal so made the best of it. Last 100 miles back the pedal starts working like perfect and pushes back up like normal. This is a puzzlement to me. Had new brake pads put in week prior and also clutch pedal acted a little funky a month earlier. Any ideas out there? Anyone know what power bleeding is? I would love to figure this out. Have read other forums and guys have replaced master and slave cylinders and still have the same problem. I sure would appreciate an explanation before burning through my money. Thank you very much. gg Very typical of 944s that have sat or the slave or master cylinder are bad or need bleeding.. Moisture is the issue usually.. Thank you guys!!!! Funny as the story is the car sat for ten years outside in palm springs.....looks it.....touch a plastic button inside and it shatters.....all timing belts and such done 7,500 miles ago.....ten years ago...so I have replaced every piece of rubber under the hood....plus about everything else....makes good sense to get new components to rule them out.....oh well....I like new....thank you again you guys gg |
theer |
Oct 2 2018, 10:20 AM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
If its not the hydraulics, sitting that long can result in the clutch fork getting stuck in the "down" position. Happened to me.. it popped back up a few days later and now works fine... could be rust on the shaft/TO bearing.
ConeDodger |
Oct 2 2018, 02:36 PM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
You can try bleeding in reverse. Jack up the front of the car and put a mityvac on the bleed screw for the slave and suck it threw that way.
There is also a spring on the pedal that could have broken. |
second wind |
Oct 2 2018, 03:27 PM
Thank you for the great ideas.....but how did it go back to perfect operation? Even though brake reservoir looked full at all times I kept adding fluid to try to force a little more in and get some pedal back. Did the car bleed some air out by chance or ???
Please keep the ideas coming in.....thank you again. gg |
porschetub |
Oct 3 2018, 01:20 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
You can try bleeding in reverse. Jack up the front of the car and put a mityvac on the bleed screw for the slave and suck it threw that way. There is also a spring on the pedal that could have broken. Exactly,very hard to get the slave cylinder to bleed conventionally ,took me severals attempts,also the piston was sticky so pulled it apart and cleaned it,cups were ok and it worked fine after. Think Rob has nailed it on the pedal return assist spring,worth checking for sure. |
Lo-Fi Version | Time is now: 9th June 2024 - 11:19 PM |
