What have I got here and recommendations with what I have?, 915 transmission (2) and unidentified axles |
Gearup |
Oct 1 2018, 04:35 PM
Member Group: Members Posts: 154 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None |
Hello,
I purchased two 915 transmissions one that is low mileage and already modified for 914use and the other a rebuilt 915 that is unmodified. I also purchased the cable shifter that goes with the transmission as well as the axles. I have a rebuilt 901 Brad Mayuer and the renegade axles to go with , however when I saw this lot for sale on Craigslist I figured it was a good enough deal to purchase all the parts that had been assembled and installed in another 914then removed. This way I know it will all come together in my car. It is all very low mileage. The converted 915 baffles me. It has been cut and another bell housing has been added and works with a Chevy heavy duty clutch. The previous owner, a wonderful older gentleman, said it had worked great in his application. So, I’m including some pictures and want your thoughts on whether I should go with them or my 330 HP V8 and 901 route or use the 915? Thanks, Brett |
mepstein |
Oct 1 2018, 04:51 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Since you have most everything you need, I would use the 915. You will need some sort of trans hanger for the back of the car. PMS used to make a semicircle hanger that was a bolt on for your application but I heard they no longer make it.
Sounds like a good score on the trans. |
Gearup |
Oct 1 2018, 04:54 PM
Gearup |
Oct 1 2018, 04:56 PM
Clutch
Attached thumbnail(s) |
Gearup |
Oct 1 2018, 04:59 PM
Axles
7153120198008LOBRO2293 GERMANY Attached thumbnail(s) |
Gearup |
Oct 1 2018, 05:19 PM
So, has anyone ever seen a modded 915 with a bellhouse like that and a Chevy clutch? Anyone know what those axles are and if any good for a high horsepower application?
Thanks Mucho, Brett |
914Sixer |
Oct 1 2018, 08:46 PM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
They look like 6 bolt 911 or 944 100mm cv's. Could be modified 914 shafts, plenty good for most hp upgrades.
Gearup |
Oct 1 2018, 09:02 PM
nditiz1 |
Oct 1 2018, 09:16 PM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
If you dont end up using that unmodified 915, I'll take it off your hands (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 6th June 2024 - 09:51 PM |
