Headlights, Headlights are not working |
Pierce |
Oct 2 2018, 02:19 PM
Newbie Group: Members Posts: 15 Joined: 4-June 18 From: Gadsden, AL Member No.: 22,191 Region Association: South East States |
On my '73 914, the headlights will pop up but the bulbs do not light. Neither does the side marker lights. I have checked the fuses and they seem fine.
Is there a relay somewhere that supplies 12V to the headlights? Any suggestions? |
TheCabinetmaker |
Oct 2 2018, 02:31 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Did they work, then just quit? Try flipping the stalk switch.I've seen either the high or low beams go out, and the other work. Usually a problem with the switch.
76-914 |
Oct 2 2018, 03:00 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/welcome.png) There is a relay for the high beam / low beam switching. Does everything else, electrical, work fine?
Front yard mechanic |
Oct 2 2018, 06:37 PM
Senior Member Group: Members Posts: 1,169 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Pull the headlight relay and test the lights there by jumping the white or the yellow if they come on it's probably the switch
Lo-Fi Version | Time is now: 1st June 2024 - 05:29 AM |
