Could someone help identify this electronically plug please? |
Tdskip |
Oct 3 2018, 11:29 AM
Good morning. Small drops of water falling from the sky here, quite odd.
I was hoping someone could identify this electrical fitting for me. It's on the 1973 1.7 FI car. Thanks! Attached thumbnail(s) |
carl k |
Oct 3 2018, 11:45 AM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
Looks like the three-port D-jet fuel pump connector.
-Carl |
Tdskip |
Oct 3 2018, 11:50 AM
Ah ha!
Let me test it to see if it has power when it should be a ignition switch position. Thanks! |
SirAndy |
Oct 3 2018, 12:14 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Ah ha! Let me test it to see if it has power when it should be a ignition switch position. It's powered through a relay on the relay board that is controlled by the FI brain. So don't expect continuous voltage with the key on. The FI brain will only power it to prime the pump and then shut it off until the engine actually starts. (IMG:style_emoticons/default/shades.gif) |
SirAndy |
Oct 3 2018, 12:16 PM
You can temporarily bypass the FI brain just to test the circuit using the article below as a reference.
http://www.914world.com/specs/SirAndyCarbFuelPumpRelay.php (IMG:style_emoticons/default/popcorn[1].gif) |
SirAndy |
Oct 3 2018, 12:17 PM
And get rid of them ugly wire crimp connectors someone hacked into the harness there ...
(IMG:style_emoticons/default/icon8.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 06:08 AM |
