1.7 Pistons, 90 mm high compression |
Downunderman |
Oct 4 2018, 04:38 PM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
Who makes forged pistons for a 1.7 with a compression ratio about 10.5:1 or thereabouts? I need to source some for my historic racer engine. TIA. Howie.
ChrisFoley |
Oct 5 2018, 06:33 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
JE or Wiseco
Downunderman |
Oct 5 2018, 03:37 PM
JE have just said they dont have an off the shelf one but will do a custom one. Waiting to hear from Wiseco.
Downunderman |
Oct 5 2018, 05:08 PM
What I want is probably what is used in F Production. What do you use Chris?
Driver174 |
Oct 12 2018, 02:10 PM
Member Group: Members Posts: 106 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None |
JE made a custom set for my 914/4 - 2.0. It was an easy process and they pretty much had all of data required. They were simple flat tops and I machined to valve pockets. Fly cutting the head down to 45cc chambers gave me 10.5:1 compression ratio.
JIM What I want is probably what is used in F Production. What do you use Chris? |
ChrisFoley |
Oct 13 2018, 10:09 AM
What I want is probably what is used in F Production. What do you use Chris? I've seen popup pistons that someone else used to get high compression without flycutting the heads too deeply, but I think that much shape on the piston crown affects the flame path too much. Cutting the heads has its drawbacks too. Mostly because one of the exhaust stud bores is very close to a combustion chamber and may break thru when trying to get below 40cc. My pistons were made to order by sending them a set of dimensions to work with. Pin height, ring groove widths, piston dia., dome height & dia. I used a stock high compression 1.7L piston as my model. I've had 91mm pistons made for 1.7L and 94mm pistons made for 1.8L. I cut my own eyebrows for the valves after doing a full mockup. |
Lo-Fi Version | Time is now: 7th June 2024 - 10:46 AM |
