John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
I've been looking for the Outside Diameter (OD) of rear 911 vented brake rotors.
If anyone knows, please let me know. Thanks, John |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
mine measure up at 290mm.
if you need a lot of decimal places, i don't have the equipment to get closer than that... |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,300 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
914/4 282
914/6 286 911 290 If you are using 914 calipers, you might as well turn them down to the appropriate diameter to reduce weight, and inertia. With the 914/4 caliper you need the clearance. The calipers will place the pads in the same place of course, so there is no braking benefit with the extra diameter. Still have a few kits available. |
joea9146 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None ![]() |
John |
Thanks for the information.
So, am I getting this right... The 911 rear rotors are larger in diameter than 911 SC front rotors. (The 914-4 and 914-6 rear rotors are both larger diameter than the 911SC rotors). I have been pondering the idea of spacing out a pair of calipers. I was going to try 914-4 rear calipers (for the e-brake), but they would be morre difficult to do as I don't know what to do with the brake pad spreader springs. The 914-4 front calipers would be easier as I could use 911 rear brake pad spreader springs (the pads are the same), but I would loose the e-brake. I suppose for the track car (that already has front calipers on the rear) this is a possibility. Any ideas on brake pad spreader springs for spaced out 914-4 rear calipers? |
davep |
My kit will help you out with most of the parts. The spreader needs to be cobbled together out of a 911 rear, for the width, and a 914/4 rear for the length. Easily done, in fact one of the easier parts to make.
Lo-Fi Version | Time is now: 31st July 2025 - 04:15 PM |
