OT - Railroad Ties, anyone know how much they weigh? |
seanery |
Jun 17 2005, 08:24 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
just curious, does anyone know the weight of a RailRoad Tie?
GWN7 |
Jun 17 2005, 08:29 AM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
From "Ask Jeeves" ..."Each railroad tie weighs and uses about 200 pounds of recyclable material. ... Polywood ties weigh 200 pounds, about the same weight of a wood tie."
But I don't think so...mabey 50 lbs |
Trekkor |
Jun 17 2005, 08:31 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
You talking about the little bow ties that the conductor might wear or the kerchief of the engineer?
What?...Oh, nevermind. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) KT ( call a landscape supply ) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
meares |
Jun 17 2005, 08:32 AM
Member Group: Members Posts: 403 Joined: 23-March 05 From: Atlanta Member No.: 3,800 |
i'm in the garbage business.......they're HEAVY, and at least in georgia, they have to be manifested........they are considered special waste
Part Pricer |
Jun 17 2005, 08:33 AM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
It depends upon the material (wood) that the tie is made from. These weights are for treated ties. Attached thumbnail(s) |
spare time toys |
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
I helped a friend whose brother works for the rail road load some up on his trailer. I wish they only were 200 pounds We need a smile holding its side where it got a hernia
rhodyguy |
Jun 17 2005, 08:36 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
my guess would be around 70 lbs sean. what do you plan to do with them? they leach out chemicals like you wouldn't believe. disposing of them is a big hassle. in wa they're considered hazzardous waste. exspensive to get rid of. they have to be shipped to a special repository(dump). they contaminate soil they come in contact with. wear old clothes you can just throw away after handling them.
k |
tat2dphreak |
Jun 17 2005, 08:38 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
200 I think is a little high, for the ones you get at the lumber yards and such... maybe 100#, but even that's pushing it...
seanery |
I ask because I bought 10 of them on Wednesday. The guy said they weighed about 100 pounds each, but I figured about twice that. I think I have either the hemlock or the oak ones...when I ran a sawzall through them they were a bit red.
thanks guys! |
tat2dphreak |
Jun 17 2005, 08:42 AM
yea, I dunno about up there... I didn't think about the different woods... they are messy bastards... I used to work in a couple lumber yards and they will wear you out... but I still think a sack of concrete(100lbs) is heavier than the ones down here... anyone who's seen me KNOWS I'm not moving 200# of anything unless it's tied to the back of a truck... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
andys |
Jun 17 2005, 09:36 AM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
I needed to make a heavy sled to level the drit in my yard to lay some sod.......Driving close to some RR tracks, I see a stack of about 6 ties in a field. Thought I'd help myself to one or two until I tried to load one by myself onto my truck.....forget it!
Andy |
J P Stein |
Jun 17 2005, 12:36 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I've never weighed one but picked up one end several times.....they are pop your gizzard heavy.
BTW, NEVER use used RR ties for anything on your property. The creosote (sp) penetrates about an inch in. The spike holes make glorius housing for critters....the ones with 6-8 legs, carpenter ants, termites...yada. They build an easy colony in there then start eyeballin' your house. |
tat2dphreak |
Jun 17 2005, 12:45 PM
so are those 'glory holes' ? (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Duffster |
Jun 17 2005, 02:38 PM
OFWG Group: Benefactors Posts: 258 Joined: 29-August 03 From: Riverside, CA Member No.: 1,087 |
Range is 208 to 240, fresh from the treater. Older they are, the lighter they get. (opposite of us!) that is a standard straight track tie. Switches and such require longer ties, and they get REALLY heavy!
tdgray |
Jun 17 2005, 02:54 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
I don't know.... what is the air speed velocity of an African Swallow (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 02:31 PM |
