> Self loosening axle bolts-will spring waters take care of this?
Tdskip
post Oct 15 2018, 07:06 AM
Good morning-hope everybody had a good weekend.
It would seem as if one of the rights of 914 ownership passages is dealing with self-loosening axle bolts.
Will the correct size spring washers from Ace deal with this, or do I need special serrated ones, or do I need to safety wire them?
Thanks in advance for the help, have a good morning.
Replies(1 - 19)
TheCabinetmaker
post Oct 15 2018, 07:38 AM
I drive my car everyday
New Schnoor washers and proper torque will keep them right. Threads need to be clean
post Oct 15 2018, 07:40 AM
914-6 GT in waiting
QUOTE(TheCabinetmaker @ Oct 15 2018, 09:38 AM) *
That’s the proper fix.
VaccaRabite
post Oct 15 2018, 07:55 AM
En Garde!
Yes the new Schnoor washers and clean threads, but adding safety wire does not hurt either.
Zach
wndsrfr
post Oct 15 2018, 08:00 AM
QUOTE(VaccaRabite @ Oct 15 2018, 05:55 AM) *
Zach
Tdskip
post Oct 15 2018, 08:08 AM
Thanks Gentlemen
914forme
post Oct 15 2018, 05:06 PM
I do that, and then safety wire them. That works every time. You do that when you are younger and drive the 914 to clients. The CV fell off on my way to one of them, no problem, except hand got covered in CV grease, luckily I knew them well, not a first impression sort of thing. Still not my most professional day. (IMG:style_emoticons/default/screwy.gif)
Same day I also discovered my fuel level sender was not working and ran out of fuel on the way back home. Murphy was batting a 1000 that day. Still had a huge smile on my face from (IMG:style_emoticons/default/driving.gif)
Tdskip
post Oct 15 2018, 07:49 PM
Pulled one to go make sure I get the right size washers. The split washers on here for apparently useless, and the threads were very greasyAttached Image
Mark Henry
post Oct 15 2018, 07:56 PM
that's what I do!
That's not a factory bolt or washer.
post Oct 15 2018, 07:57 PM
Resident German
That bolt doesn't look right, also, the center part of the threads is stripped ...
(IMG:style_emoticons/default/unsure.gif)
jcd914
post Oct 15 2018, 08:00 PM
QUOTE(Tdskip @ Oct 15 2018, 06:49 PM) *
Those bolts are not the original type of bolt used for 914 CV joints.
I would be ordering some new bolts and probably get the "drilled for safety wire" bolts since I was getting new bolts.
You need to be sure the bolts are the correct strength.
Jim
914sgofast2
post Oct 15 2018, 08:05 PM
It’s the wrong bolt for the CV joints. They are supposed to be the riebe style, which looks somewhat like an internal multi faceted Allen bolt. As already stated, you also need the special schnorr (spelling?) style of lock washers for the bolts.
Mark Henry
post Oct 15 2018, 08:06 PM
that's what I do!
QUOTE(SirAndy @ Oct 15 2018, 09:57 PM) *
Flattened, likely from banging against the loose CV.
Factory bolts /4 are only threaded part way, 8mm tri-square female. schnorr washers are thin wavy washers with teeth ridges.
914_teener
post Oct 15 2018, 09:37 PM
Go buy a lottery ticket if you had that on the freeway.
Larmo63
post Oct 15 2018, 09:56 PM
I'm pretty sure 914 Rubber sells the correct drilled ones.....?
Mikey914
post Oct 15 2018, 10:06 PM
The rubber man
Yep
https://shop.914rubber.com/914-CV-bolt-dril...m?categoryId=-1
Got the wire and tool if you need it. Also just the Schorr washers .20 each
https://shop.914rubber.com/Schnorr-washers-...-part-SCHM8.htm
pete000
post Oct 15 2018, 10:18 PM
Rebuilding my CV joints and noticed my car was missing one roll pin and had no schorr washers ! Replacing all the bolts, adding the washers. Amazed the car did not have any issues running just on roll pin on one of the joints. I guess low power application helps !
What is the torque spec for the CV bolts?
RenoRoger
post Oct 16 2018, 03:21 AM
QUOTE(pete000 @ Oct 15 2018, 09:18 PM) *
Haynes says 31lbs, others say 25 lbs
wndsrfr
post Oct 16 2018, 06:05 AM
QUOTE(Larmo63 @ Oct 15 2018, 07:56 PM) *
I've drilled some...not hard to do...1/16 bit and some quiet time...
IronHillRestorations
post Oct 16 2018, 06:22 AM
I. I. R. C.
The Schnoor washers are a one and done part, which is why we get in trouble in the early years of 914 ownership.
"Ya mean I have to get new ones every time I pull the engine?", yes.
- Lo-Fi Version Time is now: 2nd April 2026 - 12:13 PM
