Power Bleeders, Which one? |
Olympic 914 |
Oct 15 2018, 07:47 AM
Group: Members Posts: 1,672 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Am considering getting a power bleeder and had decided on the Motive #0109 when I came across the Schwaben model with pump, not the compact model.
The Schwaben is bigger at 3l but not sure that is a bonus. Price is about the same. Which do you use or recommend and any negatives to either? |
wndsrfr |
Oct 15 2018, 07:59 AM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
I've been very happy with speed bleeders ....I flush the fluid on my track car every six months...so plenty of experience.
VaccaRabite |
Oct 15 2018, 08:10 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I've got the Motive unit and have been very happy with it.
Zach |
dr.tim |
Oct 15 2018, 09:01 AM
Member Group: Members Posts: 101 Joined: 17-December 11 From: Butte, America Member No.: 13,907 Region Association: Rocky Mountains |
I have used the motive unit for more than 10 years. It works.
mepstein |
Oct 15 2018, 09:09 AM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I have used the motive unit for more than 10 years. It works. (IMG:style_emoticons/default/agree.gif) pretty easy to buy off amazon. |
JoeD |
Oct 15 2018, 01:58 PM
Member Group: Members Posts: 156 Joined: 19-July 15 From: Atlanta, GA Member No.: 18,973 Region Association: South East States |
I've got the Motive unit and have been very happy with it. Zach (IMG:style_emoticons/default/agree.gif) |
clapeza |
Oct 15 2018, 02:21 PM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
I bought the 0100 model, and it did a great job. Perfect if you don't have a helper to pump the brakes!
Amazon link: https://www.amazon.com/Motive-Products-Euro...e/dp/B0002KM5L0 |
Olympic 914 |
Oct 15 2018, 02:45 PM
So the Motive unit it is.....
Thanks for your input. |
BeatNavy |
Oct 15 2018, 03:25 PM
mb911 |
Oct 15 2018, 04:55 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I need to buy one of these.. Are all 0100 models the same? I see wide range of prices..
914forme |
Oct 15 2018, 05:00 PM
Different adapters for different master cylinders. You can also get the pro adapters made from AL. You can buy the fittings separate also, and adapt stock caps if you have an odd one or two.
mepstein |
carr914 |
Oct 15 2018, 05:38 PM
Racer from Birth Group: Members Posts: 118,899 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I have used the motive unit for more than 10 years. It works. (IMG:style_emoticons/default/agree.gif) pretty easy to buy off amazon. I happened to buy one today from Pelican ( I had a 10% off coupon). I bought the Black Label model. |
Mark Henry |
Oct 15 2018, 07:54 PM
Speed bleeders are nice, but I couldn't find them for my Alfa/Brembos. bleeders are big, maybe 10mm. So I only have them on my rears.
mepstein |
Oct 15 2018, 07:57 PM
I have used the motive unit for more than 10 years. It works. (IMG:style_emoticons/default/agree.gif) pretty easy to buy off amazon. I happened to buy one today from Pelican ( I had a 10% off coupon). I bought the Black Label model. Pelican has a lot of good stuff but I’m spoiled by Amazon prime. |
carr914 |
Oct 16 2018, 04:27 AM
I know a lot of people love Amazon, but not me. I avoid them at all costs.
mb911 |
Oct 16 2018, 05:44 AM
You guys talked me into buying one.. Should be here in a week. (IMG:style_emoticons/default/sad.gif)
iankarr |
Oct 16 2018, 04:38 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
You’ll love it. The lines between the reservoir and MC aren’t designed for pressure so go easy. I use about 5psi to bleed the system.
mepstein |
Oct 16 2018, 05:13 PM
You’ll love it. The lines between the reservoir and MC aren’t designed for pressure so go easy. I use about 5psi to bleed the system. The first time I used one I was told 40. Then I learned that was way too much. (IMG:style_emoticons/default/headbang.gif) |
mb911 |
Oct 16 2018, 05:15 PM
Lo-Fi Version | Time is now: 1st June 2024 - 02:23 AM |
