1971 1.7 liter, looking for tachometer cable |
milwlandrover |
Oct 19 2018, 07:50 AM
Member Group: Members Posts: 149 Joined: 22-June 12 From: Greendale Wisconsin Member No.: 14,592 Region Association: Upper MidWest |
I am looking for a tachometer cable. when doing the transmission I found my original cable wrapped around the axle. I had to cut it off and I can not find a replacement cable or any tech info on how to replace it. I found lots of speedometer cables when I input tachometer cable in the search but that is not what I need. Any ideas out there?
thanks and cheers! |
mgphoto |
Oct 19 2018, 08:10 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Tach is electronic, no cable, just a single wire from the coil.
Speedo cable, accelerator cable and heater cables, that’s it. |
TheCabinetmaker |
Oct 19 2018, 09:20 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
It's a speedo cable
milwlandrover |
Oct 19 2018, 09:54 AM
My speedo is working really well. The tach is not, that is why I assumed the cable wrapped around the axel was for the tach. But that answers why all my searches for the tach cable were fruitless
I suppose the best place to start would be to remove the tach for inspection.... correct? |
ChrisFoley |
Oct 19 2018, 09:59 AM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
How about a picture of the cable you removed? Was it on the driver side? Could it be the backup light wires?
The tachometer is driven by a thin black/red wire attached to the negative terminal of the coil. |
milwlandrover |
Oct 19 2018, 11:17 AM
the cable was so damaged I just tossed it. It was on the passenger side of the axel. I can look a little closer tonight. Perhaps I will see a loose end of the original cable but I did not see anything when I did the brakes.
mgphoto |
Oct 19 2018, 03:39 PM
the cable was so damaged I just tossed it. It was on the passenger side of the axel. I can look a little closer tonight. Perhaps I will see a loose end of the original cable but I did not see anything when I did the brakes. Could be e-brake cable, one on either side, maybe just long enough to reach the axle? |
rgalla9146 |
Oct 19 2018, 05:33 PM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Check the arm on the bottom of the pass. rear caliper, is there a cable attached to the trailing arm and the caliper ?
Lo-Fi Version | Time is now: 22nd May 2024 - 11:57 PM |
