ammason |
Member ![]() ![]() Group: Members Posts: 88 Joined: 14-March 05 From: Sunny Honolulu Member No.: 3,758 Region Association: Hawaii ![]() |
I noticed a few days ago that going over bumps I hear a small *clunk*, like something big is moving a few 1/100ths of an inch - when I back up sometimes as well...
I checked my front wheels and when I yanked on the passenges side, there's a small bit of play. I've also noticed that when I get up to about 70mph, the steering wheel picks up a vibration. I noticed the vibration about two weeks ago and attributed it to the road I was driving on, but it seems now that it does it any time the car ist at speed. I'm going to check it tomorrow when I spend some time with the girl, but what might cause this? The only thing I can think of off the top of my head would be a tie rod bushing. It doesn't feel like a wheel bearing... Ideas? Cheers! |
mihai914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None ![]() ![]() |
First make sure that every bolt around the suspension is tight.
It mostly sounds like a tie-rod end. You can replace it with a stock one or go for a Turbo Tie-Rod kit from vendors. You should also check the ball-joint, if they have slack they can give the impression of bad tie-rods also. Of course a proper alignment will be due afterwards. Edit: mayne nalancing the front tires wouldn't be a bad idea either. |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
This doesn't sound like your problem, but Marty Yeoman had a noise that seemed to be coming from the large rear bolts for the cover plate under the steering rack. They were just a hair too long (replacements) and it was allowing the mounts to "click" 0.001" or so.
Lo-Fi Version | Time is now: 7th July 2025 - 04:05 AM |
