URGENT HELP REQUIRED, Trouble shooting Fuel System |
dagdal1967 |
Jul 14 2003, 08:34 AM
What are YOU looking at... Group: Members Posts: 372 Joined: 13-March 03 From: Carrollton, Texas Member No.: 423 |
Gentlemen,
Got in the car to start it yesterday and it would not start. We've managed to trace the problem down to the fact that the fuel pump is not getting any power. Can anyone help us with troubleshooting what too look at next. We know that the power is switched through the Fuel Pump relay on the relay board, but dont really know what or how to check there. Would really like to talk to someone ASAP as I only have limited hold over my brother/mechanic! (IMG:style_emoticons/default/ohmy.gif) Anyone willing to speak real time would be greatly appreciated! Thanks in advance!! Doug |
JFJ914 |
Jul 14 2003, 08:55 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
Try Brad Anders site, http://members.rennlist.com/pbanders/ , there is a comprehensive D-Jet section containing flow charts to guide you.
John Jentz |
Bleyseng |
Jul 14 2003, 08:58 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Change the fuel pump relay with another one, they do go bad or the contacts get junked up preventing the flow of electricity.
Geoff |
URY914 |
Jul 14 2003, 09:03 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,010 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I've had to run a wire from the hot side of the coil directly to the pump. Then you'll if it the pump, or a relay, fuse etc. Try it but be careful you don't touch that hot wire to anything else.
Paul |
tod914 |
Jul 14 2003, 09:45 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
If the fuse (not the relay), keeps blowing while your testing this, it could also be your AAR. They share the same fuse. You could disconnect the aar to check if indeed that is happening. dont ask me how i know (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/headbang.gif)
dagdal1967 |
Jul 14 2003, 12:11 PM
PROBLEM SOLVED.
We managed to test the fuel pump and it was fine so we started tracking the wiring starting with the relay board. Thank goodness for my workshop manual that had the full schematic! With a bit of trial and error and a bit of luck we managed to find out that one of the Fuel Pump Relays was bad. I replaced it with the Hot Air Blower relay and It started like a charm. I'll just have to get a replacement for the hot air blower and at least a spare. Anyone know if you can get these anywhere outside of the obvious PP/AA? Do larger Auto parts stores or VW dealers carry them?? Thanks Doug |
tod914 |
Jul 14 2003, 12:14 PM
Id buy them from porsche. That way you get a german made 1. Most of the other parts places sell ones made in china.
seanery |
Jul 14 2003, 02:37 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Rich Bontempi has them at HPH.
I bought a couple when I was there. www.highperformancehouse.com |
ein 6er |
Jul 14 2003, 03:02 PM
Senior Member Group: Benefactors Posts: 1,115 Joined: 11-February 03 Member No.: 300 Region Association: None |
hey doug,
once, i had a fuel pump relay go bad on a 74 2.0. IIRC the pump stayed on with key off. at the time, (early 80s), i didn't know you could swap relays. so i opened the relay, there is a small breaker point that opens and closes for the pump. i had to put a toothpic between the points to shut off the pump. when i went somewhere i would pull the toothpic and start the car. when i got to where i was going i had put the pic back in!! worked great until i could find another relay!! doug waters |
dagdal1967 |
Jul 20 2003, 07:14 AM
QUOTE(ein 6er @ Jul 14 2003, 01:02 PM) hey doug, once, i had a fuel pump relay go bad on a 74 2.0. IIRC the pump stayed on with key off. at the time, (early 80s), i didn't know you could swap relays. so i opened the relay, there is a small breaker point that opens and closes for the pump. i had to put a toothpic between the points to shut off the pump. when i went somewhere i would pull the toothpic and start the car. when i got to where i was going i had put the pic back in!! worked great until i could find another relay!! doug waters LOL.. Necessity, the mother of invention! I took my old relay apart as well and went through it with a multi-tester. Somewhere in the coil, there was a break in continuity, so no such luck for me. I've ordered new relays and they should be here tomorrow. Back to normal !!! Thanks again for tall the help guys. Doug |
Lo-Fi Version | Time is now: 6th June 2024 - 03:08 AM |
