> Engine Grill removal question
trawler
post Nov 8 2018, 05:03 PM
Region Association: England
Hi again. The "P" of Porsche is not gapped the same as other letters and it is giving me OCD. My question is... How do I take the grill off to adjust the position of the letter? I dont want to go at it with a screwdriver or blunt instrument without knowing the method. Thanks in advance T
Replies(1 - 6)
post Nov 8 2018, 05:05 PM
914-6 GT in waiting
Remove the speed nuts on the back very carefully. The plastic posts on the letters snap of easily.
Mikey914
post Nov 8 2018, 05:52 PM
The rubber man
You will need to remove the rain tray, if it's installed.
Spoke
post Nov 8 2018, 06:01 PM
Jerry
You'll be best served to remove the entire hood and work on it on a piece of carpet in your work area or in the house somewhere. 2 bolts and the entire hood comes off. It can be a one man job to remove it. 2 people is easier.
Working on the hood or even engine with the hood in place is difficult. I slotted the hood hing holes so I don't have to remove the bolts all the way to remove the hood.
aharder
post Nov 8 2018, 08:23 PM
QUOTE(Spoke @ Nov 8 2018, 06:01 PM) *
You'll be best served to remove the entire hood and work on it on a piece of carpet in your work area. 2 bolts and the entire hood comes off. It can be a one man job to remove it. 2 people is easier.
This is the Slot Spoke is referring to:
To Marks Point, Once you remove the rain Tray, you should be able to access the letters on the grill
I just finished working on my engine deck lid.
trawler
post Nov 14 2018, 02:06 PM
Thanks for all the advice, i will pluck up courage to get on with it now.
raynekat
post Nov 14 2018, 06:28 PM
Depending on the type of speed nut used and the fact that you're only adjusting one letter.....you might be able to do this small job with the lid still on the car. I've had to carefully use a dremel cut off wheel to get some speed nuts/clips off.
- Lo-Fi Version Time is now: 22nd September 2026 - 08:26 AM
