Pedal Cluster Removal Question, Clutch Cable |
tvdinnerbythepool |
Nov 26 2018, 06:29 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Hey guys,
Going to rebuild my pedal cluster, and at the point of disconnecting the clutch cable at the clevis by the cluster. Should I loosen or disconnect the cable at the trans before disconnecting up front? Thx! |
Chris914n6 |
Nov 26 2018, 07:45 PM
Jackstands are my life. Group: Members Posts: 3,338 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
It's usually under a bit of tension, so yes, loosen the trans side first.
I like to fasten a twist tie as a marker to get it back in the same spot. |
Lo-Fi Version | Time is now: 11th June 2024 - 03:04 AM |
