Swapping flywheels and end play |
yeahmag |
Dec 4 2018, 12:23 AM
Advanced Member Group: Members Posts: 2,424 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I’m getting ready to swap flywheels and was pondering end play. Assuming the new flywheel has the same measurement from the thrust surface to the crank mating surface the end play should be the same. Right?
914 Ranch |
Dec 4 2018, 02:49 AM
Team Sharp where the 914 grow wings Group: Members Posts: 1,419 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
I’m getting ready to swap flywheels and was pondering end play. Assuming the new flywheel has the same measurement from the thrust surface to the crank mating surface the end play should be the same. Right? Not, everyone is different. Got to set the end play. I set it every time I have the case's apart. |
Olympic 914 |
Dec 4 2018, 08:51 AM
Group: Members Posts: 1,677 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
I’m getting ready to swap flywheels and was pondering end play. Assuming the new flywheel has the same measurement from the thrust surface to the crank mating surface the end play should be the same. Right? Not, everyone is different. Got to set the end play. I set it every time I have the case's apart. (IMG:style_emoticons/default/agree.gif) When I built my engine the end play was on the loose side of the range but with the available shims it was either that or too tight at something like .0025. then when having the engine out again for a suspected RMS leak at 2K miles I discovered the end play had opened up some, and by switching shims got it too a much more respectable .0032 I would check it anytime the trans is off the cases. |
Lo-Fi Version | Time is now: 11th June 2024 - 10:19 PM |
