Door Hinges, Has anyone ever taken them apart. |
ClayPerrine |
Dec 6 2018, 03:29 PM
Life's been good to me so far..... Group: Admin Posts: 15,518 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
With all the mileage on Betty's car, we have found that the hinges on the driver's door are squeaking really badly from wear. Does anyone have experiencing taking the pins out of the hinges so they can be re-bushed?
This is really irritating her every time she opens the door on her car. She says it makes the car sound old. (IMG:style_emoticons/default/sad.gif) |
mepstein |
Dec 6 2018, 03:34 PM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
They come apart easily once you remove the C clips. I would just find a replacement. It's usually just the driver door since it gets used so much more.
Rand |
Dec 6 2018, 03:44 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Lube?
sixnotfour |
Dec 6 2018, 05:14 PM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
C clips . ?? mine doesnt have em,,,the factory door pin slde hammer is the best tool ever for this ...special offset slides over pin head..
https://www.aasesales.com/products/noloc-b52-189i-116012 Attached image(s) |
mepstein |
Dec 6 2018, 05:54 PM
C clips . ?? mine doesnt have em,,,the factory door pin slde hammer is the best tool ever for this ...special offset slides over pin head.. https://www.aasesales.com/products/noloc-b52-189i-116012 Sorry, I was thinking the door stop mech. |
IronHillRestorations |
Dec 6 2018, 08:20 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
There's a special washer between the two hinge sections, it's very thin and without it the door can squeek and have some up/down slop on the latch side of the door. I'll bet the one in Betty's car is gone.
ClayPerrine |
Dec 7 2018, 07:46 AM
Thanks everyone. I would never have known about the tool without this forum.
I have a door up in the attic that is an accident victim I am going to bring down and figure out how to take the hinge apart. Then I will use the parts to repair hers. Also thinking about buying the tool. One can never have enough tools. |
davesprinkle |
Dec 7 2018, 11:26 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
My driver's door had the same squeaking problem. I was able to resolve it by lubricating the joints with lightweight mineral oil. I used Tri-Flow from my bicycle shop, but anything similar would work: sewing machine oil, 3-in-1 oil, gun oil, whatever. I applied the oil to the each of the segments in the hinge, worked, the door open and closed a few times, then drank a couple of beers. Did that four times. No more squeaks.
Larmo63 |
Dec 7 2018, 11:31 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
"I applied the oil to the each of the segments in the hinge, worked, the door open and closed a few times, then drank a couple of beers. Did that four times. No more squeaks."
So, did you drink eight beers? (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
davesprinkle |
Dec 7 2018, 11:56 PM
"I applied the oil to the each of the segments in the hinge, worked, the door open and closed a few times, then drank a couple of beers. Did that four times. No more squeaks." So, did you drink eight beers? (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) Uh, yeah. You got a problem with that? |
jim_hoyland |
Dec 8 2018, 07:00 AM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I have a door up in the attic that is an accident victim I am going to bring down and figure out how to take the hinge apart. Then I will use the parts to repair hers. Show us some pics when you get started; gotta be some new info here.... (IMG:style_emoticons/default/smile.gif) |
mepstein |
Dec 8 2018, 07:51 AM
I have a door up in the attic that is an accident victim I am going to bring down and figure out how to take the hinge apart. Then I will use the parts to repair hers. Show us some pics when you get started; gotta be some new info here.... (IMG:style_emoticons/default/smile.gif) I sent some hinge parts to a member here. the pin dropped out pretty easily with a punch and hammer. I was ready to use some heat but didn't need it. |
colingreene |
Dec 9 2018, 12:00 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
The slide hammer is essential for pulling the pins on the car.
I had to put new bushings in my 911 i bought because the door sagged. Pelican parts sells them but not the hammer. If you were local id say come by and use the one I made. |
aharder |
Dec 9 2018, 12:30 PM
Advanced Member Group: Members Posts: 4,411 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
sixnotfour |
Dec 9 2018, 02:05 PM
I was lucky,,a shop selling out did not know what is was for..
Lo-Fi Version | Time is now: 9th June 2024 - 03:33 AM |
