Vertical Targa Seal Installation, Is this what it should look like? |
Highland |
Dec 8 2018, 05:43 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
First, thanks to 914 Rubber for getting the Black Friday orders out so fast. I was not expecting parts for some time.
Is this what the vertical targa seal should look like with the window all the way up? I want to verify before I cut the excess off the bottom. Also, for any of you who have installed 914 Rubber's triangle window seal, do we have to cut our own slot (on the bottom) for the metal mount tab? |
BeatNavy |
Dec 8 2018, 06:09 PM
Also, for any of you who have installed 914 Rubber's triangle window seal, do we have to cut our own slot (on the bottom) for the metal mount tab? If you have an early car with the bracket you either need to cut a slot or remove the bracket. Either will work, although I don't know which would be preferred, honestly. I think I may have done one way on passenger side and the other on driver. |
rgalla9146 |
Dec 8 2018, 06:39 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The upper pointy tip of the aluminum holder and the tip of the seal should
match. Put the roof on and start adjustin' Ideally the 45 degree ends of the two seals should be virtually touching. Is your window fully up ? Tinted glass.....mmmmmm. |
Highland |
Dec 8 2018, 06:50 PM
Yes, my window is fully up. Do I need to adjust it to go higher?
Does anyone have a picture of an ideal setup? Oh, the car is a 73, so I think everything is late. |
Chris914n6 |
Dec 8 2018, 07:57 PM
Jackstands are my life. Group: Members Posts: 3,337 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Rubber tends to shrink with age, so I usually squish it in. Also might still be stretched from a tight fit during install. But it might have been cut long, some other 914rubber seals are cut to fit.
HansJan |
Dec 9 2018, 03:01 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 9th June 2024 - 10:07 AM |
