2.0 fuel injector connector broke how to repair, The plastic fi broke off harness. how to fix? |
buck toenges |
Dec 11 2018, 01:16 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
dr914@autoatlanta.com |
Dec 11 2018, 01:35 PM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
splice on a new connector by soldering and heat shrinking, easiest way. We have all of the plugs and boots if you cannot find them, also we have the female ends and hollow connectors if you want to get more sophisticated
The plastic connector for a fuel injection connector broke off. I have a new one to replace but which wire goes to the correct side of the connector? What do you have to do to make sure it is wired correctly? What is the best way to connect the wires to the harness? Thanks, Buck |
rjames |
Dec 11 2018, 02:14 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Mblizzard |
Dec 11 2018, 02:15 PM
I have a new one to replace but which wire goes to the correct side of the connector? [b]What do you have to do to make sure it is wired correctly? I was told that it doesn't matter. The injector will work either way. Yep that is correct! |
TheCabinetmaker |
Dec 11 2018, 04:36 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Yes. Doesn't matter.
Lo-Fi Version | Time is now: 9th June 2024 - 02:04 PM |
