Greg Bell |
Member ![]() ![]() Group: Members Posts: 137 Joined: 3-May 05 From: Warner Robins, GA Member No.: 4,024 ![]() |
Guys, I was vaccuming my pedal area so I removed the wooden board. I forgot to take a pic beforehand so I need you guys to show me the correct placement for the metal doohickey behind the clutch hole.
Is this correct, or should the black thing be behind the board? Attached image(s) ![]() |
mihai914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None ![]() ![]() |
Follow the washer marks, they will guide you (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Looks good to me.
Greg Bell |
I said I was an idiot! I was just woried that the black thing was supposed to be behind the wood (Although my brain said no). What is that thing?
mihai914 |
Clutch pedal stopper, prevents you from hitting the floor and stretching the clutch cable too much and having another winter project.
Greg Bell |
Thanks, I supposed they intended it to be adjustable up and down? Hmm. Why? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,248 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
yes, that's correct ...
that "doohickey" is the stop for the clutch-pedal. without it (or mal-adjusted) you will overstretch your clutch cable and if you're lucky, you'll "only" brake the cable, if you're not so lucky, you'll brake the clutch tube inside the center tunnel ... the "black thing" is where your clutch pedal rod is supposed to hit the stop ... btw. clutch stop adjustement (as well as throttle stop adjustement) is done best with 2 poeple, one in the back watching the clutch arm (working the throttle) and one adjusting the pedal stop accordingly ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
redshift |
The stop shouldn't need adjusting 99/100 in a complete car...
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) M |
SirAndy |
because no two clutches are the same (wear, resurfaced etc etc). once the clutch arm is all the way in (disengaging the clutch) moving the pedal further down will only stretch the cable but not move the clutch arm any further (cause it can't go anywhere once it's all the way in) ... so what you do is, you pull down the clutch pedal (by hand) and have a buddy check the clutch arm in the rear. once the arm hits it's max. movement you adjust the stop so you can't move the pedal any further down ... same with the throttle stop behind the gas pedal. have a buddy move the throttle body on the engine to WOT and hold it there. then you move down the accel. pedal until you feel the cable to be tight. then adjust the gas-pedal-stop so you can't move the gaspedal any further down ... doing this will greatly prolong the life of your cables and save you the major headache of rewelding your clutch tube ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
SirAndy |
au contraire my goatloving friend ... i have found that 95/100 cars don't have the pedal stops set correctly ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
redshift |
Greg Bell |
So, should I be worried? I just installed it where the old washers had left an imprint.
RoadGlue |
Sonoma County Gear Head ![]() ![]() ![]() ![]() Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California ![]() ![]() |
Hijaaked! Does anyone have the rubber for the pedal stop? Mine left this world many many moons ago. Now that I've rebuilt my cluster and have the Alumunium board (thanks Engman!) I want the rubber stop. Anyone?
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
SirAndy |
yes. i'd be worried. you never know if the PO knew what he was doing. get a helping hand and adjust it once and be done with it ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
GWN7 |
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region ![]() |
The hard part would be replicating the metal bracket the rubber is held by (if that's missing also). If you can't find the rubber let me know. Simple cavity mold. |
RoadGlue |
I just need the rubber. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) PM Sent. Thanks! |
Greg Bell |
"yes. i'd be worried. you never know if the PO knew what he was doing. get a helping hand and adjust it once and be done with it ..."
Could it hold off till next weekend if I clutch lightly? (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
redshift |
Hold off on replacing the stop?
Sure... I never even fully depress the pedal. M |
jgiroux67 |
Guitar Shredder ![]() ![]() ![]() Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 ![]() |
How do you know if the clutch tube is busted or the cables are shot?
Lo-Fi Version | Time is now: 8th July 2025 - 12:59 PM |
